Headlight adjustment that has not been asked that is very informative if answered....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sincitytaco, Apr 25, 2009.
  1. Apr 25, 2009 at 3:49 PM
    sincitytaco
    sincitytaco [OP] Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    With the vertical adjustment knob. I am planning on marking the top of where it is now and counting the turns so I can do the exact same adjustment on the other side.
    My question is: Will both headlights still be even. Do they both move exactly the same as with a set of coilovers. 1 turn will lift all corners the same amount. I just want to make sure that 1 full turn means the same for right and left. I know of some situations where they may be different and I will use another method if that is the case.
    I am sure very few know the real answer to this so please only comment if you are for sure.
    Thanks.
  2. Apr 25, 2009 at 4:18 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    don't think the amount of turns is going to be equal on those light adjusters. Just pull up to a wall or garage door and turn until they are 'aligned'
  3. Apr 25, 2009 at 4:36 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    Ideally, they should be the same... Thread pitch should be the same, so therefore the movement should be the same...
  4. Apr 25, 2009 at 4:44 PM
    sincitytaco
    Las Vegas
    Also I have found a diagram on here that shows the back of the headlight. It shows the vertical adjustment knob and says "clockwise = up and Counterclockwise = down" is this for the knob itself or for the screw driver you are using to adjust it. Because if you turn the screw driver clockwise obviously the knob would turn counterclockwise.
  5. Apr 26, 2009 at 10:07 AM
    sincitytaco
    Las Vegas
    nobody, come on guys....
  6. Apr 26, 2009 at 10:18 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Screwdriver takes forever.... For the vertical I used an air ratchet. I think it's an 8MM socket on the back.
  7. Apr 26, 2009 at 10:24 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    Most headlights are adjusted with the driver's side light a little lower to protect the vision of oncoming traffic. If you have rasised the vehicle you want to be especially careful with this.
    It is not real expensive to have your headlights adjusted by a professional and the rest of us driving on the road with you would dearly appreciate you spending the money.
    YMMV
  8. Apr 26, 2009 at 10:25 AM
    sincitytaco
    Las Vegas
    How the hell can it take so long. How can you adjust it with any accuracy using an air tool. Not to mention I would be scared to break something using an air tool. I figured I would lower each one about 10 turns or so on the adjustment knob, but from what you are saying I may need to lower it about 500 times or so, WEIRD.
  9. Apr 26, 2009 at 10:26 AM
    sincitytaco
    Las Vegas
    Do you all want to chip in on the costs?
  10. Jun 6, 2010 at 7:17 PM
    taco_man
    taco_man Well-Known Member
    Austin
    Houston
    09 texas edition
    Borla exhaust, K&N intake, Full sound system
    am i suppose to be ratchiting forever on these things because i haven't seen much movement...
  11. Jun 6, 2010 at 9:45 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    ^ yea, if your using a ratchet, it could take awhile...i just move them w/ my fingers to adjust them now days.
  12. Jun 6, 2010 at 10:12 PM
    BrandonTorgerson
    BrandonTorgerson Well-Known Member
    Brandon
    Signal Hill, Ca
    09 Tacoma TRD Sport 4X4
    Camburg 3'' lift 2.5 coilover race runner shocks, uni-ball upper arms by camburg, AllPro 11 leaf pack with fox 2.0 performance shocks, TRD Cold air intake, TRD Cat Back System, 285/70/R17 BFG MT KM2s On Balistic Inigmas
    yeah same here.. i found level ground or for the most part. pull up to the garage wall and turned the head lights on only. no fogs... then pop the hood and you can use you hands to do it, there not that tight to use tools... at least not for me. from about 8 feet away you will see two brighter glare points. just make sure that they are in line vertically... thats what i did and now i'm not getting flashed any more. i went about 10 turns. i also took it and drove it around after 5 turns and noticed that it was still not enough, so 5 more turns did it... hope this helps
  13. Jun 6, 2010 at 10:36 PM
    lookylookitzadam
    lookylookitzadam Retrofit Club!
    Adam
    San Diego
    07 DC OffRoad
    I used a drill with extension bits to adjust, takes a while by hand...
    in any case, it doesnt matter if they are the same (theoretically the each rotation will move it the same amount, however starting points will vary), just adjust to your liking.
  14. Jun 7, 2010 at 6:46 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    ...theory vs. reality... is what may bite you.
    In theory, yes, same number of turns should net you the same movement.
    Reality, from my experience anyway, is that after a certain number of turns my HLs stopped moving before they got to where I needed them to be. I had to back off the height adjustment a bit, then turn the horizontal adjuster a bit (l then r), then the height would adjust down to where it needed to be. I.e, it seemed to "stick" at a certain spot, then I had to mess with the adjusters before it would move properly again.
    I used a flexible extension, a screwdriver bit, and a cordless drill (at slow speed) to adjust mine. Didn't count turns, just got them to where they needed to be.
    If you do count turns, I would make sure that you're in front of a wall, as suggested by other posters, then ensure that the HL is moving as you adjust it. If it moves for every turn, you should be good.
  15. Jun 7, 2010 at 6:57 AM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Pro grille, remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    ^^ This
  16. Jun 7, 2010 at 7:03 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    Sold my truck Jan '13... Still hang around.
    I agree that it's unlikely that adjusting the lights the same number of turns will yield the exact same results. The lights probably aren't exactly the same on both sides now anyways.
    Just use a white wall. Set one where you want it, and fiddle with the other one until it matches.
