Headlight adjustment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BrotherJohnny14, Feb 28, 2022.
  1. Feb 28, 2022 at 4:18 PM
    BrotherJohnny14
    BrotherJohnny14 [OP] Well-Known Member
    Johnny
    Virginia
    1995 Tacoma extended cab SR5
    Bought some Spec D headlights back in December. Me being the idiot I am I waited until now to try to adjust the headlights (mainly because I don’t have any where to park flat and make adjustments) anyway, I went to a parking garage today and was trying to adjust the headlights best I could. Seems like the headlights aren’t really level. There are to two set screws to adjust the height and side to side but nothing that I’m aware of to balance the levelness of the headlights. Anybody now any tricks around this to possibly level the beam?
  2. Feb 28, 2022 at 6:22 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Can you describe Levelness?
  3. Feb 28, 2022 at 8:28 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Are you trying to say the headlight cut-off beam isn't level? Might just be poor quality housings. My 2015 cutoff is perfectly horizontal
  4. Mar 1, 2022 at 3:03 AM
    BrotherJohnny14
    Johnny
    Virginia
    It’s not a straight line. One of the headlights is running at an angle like it’s going down hill from left to right
  5. Mar 1, 2022 at 3:03 AM
    BrotherJohnny14
    Johnny
    Virginia
    Not sure what you exactly call it. It’s not a straight line left to right. One of them looks like it’s running down hill
  6. Mar 1, 2022 at 3:19 AM
    Icarus II
    Icarus II Well-Known Member
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    Left to right? Do you mean driver’s to passengers or the other way around?
    If you’re in the driver’s seat, the passenger side will cast more light up and to the right.
  7. Mar 1, 2022 at 4:34 AM
    BrotherJohnny14
    Johnny
    Virginia
    No. I understand that. I understand you have “steps” in each headlight. I’m saying if I cover up my passenger headlight and only cast my driver light it is not a flat line horizontally. It’s angled downhill going from drivers to passengers. It’s suppose to be a straight aside from the step in it
  8. Mar 1, 2022 at 4:38 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I am guessing 1 of 2 things. Either you will need to go back in and reseat the bulb in the housing as something may be funky there, or the reflector bucket itself may be at an angle in which case there's really nothing you can do via easy means.
    DG92071 and Goldwrench like this.
