headlight adjustments
Discussion in 'Lighting' started by toyotagal, Oct 4, 2009.
  1. Oct 4, 2009 at 1:45 PM
    toyotagal
    toyotagal [OP] Member
    Jolene
    Estacada, Oregon
    02 tacoma 4x4
    Hey there, I'm new to this, so please bare with me. I need to adjust my headlights and not sure how to go about this. I just changed both bulbs, one is brighter and higher than the other. Can someone tell me how to adjust these?:help:
  2. Oct 4, 2009 at 1:47 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven
    '17 Inferno DCSB O/R
    STOCK 4 NOW
    one is brighter than the other or they are not projecting at the same angle? if one is brighter that is a light bulb problem. cant really "adjust" that i dont think
  3. Oct 4, 2009 at 1:51 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Hmmm, I use a phillips screwdriver to adjust mine. They look like little gears and I just stick the screwjy in there and twist until there level. There are 2 gears looking things, one is for up and down and the other is side to side....hope this helps :eek:
    :Edit: Should've read all the way through
    and I would've seen you were talkin
    about brightness :eek:
  4. Oct 4, 2009 at 1:54 PM
    jaxchrisfla
    jaxchrisfla Well-Known Member
    flooriduh
    lots
    also make sure both are seated correctedly. that is easily over seen.
  5. Oct 4, 2009 at 2:47 PM
    toyotagal
    Jolene
    Estacada, Oregon
    02 tacoma 4x4
    How do I know that I seated the bulbs correctly? And yes, I replaced them myself!:)
  6. Oct 4, 2009 at 2:49 PM
    toyotagal
    Jolene
    Estacada, Oregon
    02 tacoma 4x4
    Where do I locate the "gears" to adjust them up and down? I'm doing this solo and I thank you in advance:eek:
  7. Oct 4, 2009 at 4:49 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
  8. Oct 4, 2009 at 10:24 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    +1
    Don't adjust them! Leave them as is from the factory. If you headlights were properly and evenly leveled before, there should not be a reason why you would have to adjust them again. Definite get a flashlight in there and make sure all 3 tabs are in the indentations before you push that metal clip over them.
