Headlight advice
Discussion in 'Lighting' started by BigBlack08Taco, Apr 14, 2016.
  1. Apr 14, 2016 at 12:48 PM
    BigBlack08Taco
    BigBlack08Taco [OP] New Member
    Hey guys,
    Long time reader, first time poster.
    I need new headlights, and was hoping someone could help clear my confusion. The situation is I have an '08, I did the BHLM about 4 years ago and was pretty happy with the look, but then my headlight housings/lenses started to fade and dull. Last summer I sanded them and sealed them but now they look 10 times worse than before.
    So I was hoping to find a plug-n-play headlight, something a little brighter with an updated look - projectors, eagle eyes, etc.
    Where I'm getting stuck is that there seem to be a lot of negative reviews on every headlight out there, and unclear info on what level of labor is required. It seems there are no aftermarket headlights that don't have fogging issues, and I don't want something that will require hours of work - be it wiring, retrofitting, etc. I just want something clean looking and easy to install, in the $300 range.
    So....any suggestions? I've had these IPCW lights in my Amazon cart for a week, but I'm hesitant to pull the trigger without knowing more: http://www.amazon.com/IPCW-CWS-2040B2-Toyota-Tacoma-Projector/dp/B0071CSK3Y
    Thanks guys!
  2. Apr 14, 2016 at 12:48 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    DEPO is best aftermarket BHLM.
  3. Apr 14, 2016 at 12:51 PM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    I too want to know a good "plug and play" headlight for a 2nd gen...sub'd for responses.
  4. Apr 14, 2016 at 12:53 PM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    @DCSBFTMFW is correct, get the DEPO and be happy, it wont ever hurt to seal the outside of them with RTV or Silicone when you receive them though
  5. Apr 14, 2016 at 12:58 PM
    BigBlack08Taco
    Thanks for the replies. Is there an easy HID install, or am I stuck with incandescent if I want easy?
  6. Apr 14, 2016 at 1:05 PM
    Red Baron
    Aaron
    07 Radiant Red DCSB
    Get the new housings and get a HID kit, they are pretty easy and straight forward
  7. Apr 14, 2016 at 1:07 PM
    oh crap its him
    oh crap its him Well-Known Member
    Shannon
    OH->SLC,UT->SA,TX
    09 TRD OR
    Lift, Wheels, Lights
    Depo are decent. I have them on my truck and they lasted almost a whole year before the clearcoat started peeling on them, and a year and a half before they started getting moisture on the inside. A second sealing with silicone seems to have done the trick so far.
  8. Apr 14, 2016 at 1:36 PM
    T4RFTMFW
    HID isn't easy, IMO. Epecially budget kits.
    If you don't want finicky stay with halogen.
  9. Apr 14, 2016 at 8:21 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  10. Apr 15, 2016 at 6:37 AM
    BigBlack08Taco
    Thanks again for all the replies. I went ahead and bought the Depo housings, figured that at least fixes the worst part of the problem, and then I can decide later if I want to try to convert them to a different type.
    Crashnburn- again, I don't want to waste another weekend trying to fix 8 year old OEM housings, but thanks. I may eventually try a higher wattage bulb like you posted, but since it would probably be ill advised to run a higher power bulb without a new wiring harness, I'll push that decision off for later. I'm thinking if I'm going to invest the time to do that, I may as well just install HIDs.
