Headlight assembly and led/hid conversion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MillerMan06, Oct 23, 2018.
  1. Oct 23, 2018 at 1:59 PM
    MillerMan06
    MillerMan06 [OP] Well-Known Member
    Adam
    Raleigh
    06 PreRunner SR5
    K&N Cold Air Intake,Running boards,bed cover,windows tinted, MagLite seat mount (A big Thankyou to piercedtiger for that one got it off cheap/free mods) extra 4 outlets on the 12V plug 3 12V plug in's and a USB all one box with toggles,48LED dome light (blue), Tail gate theft mod,Exhaust flowmaster super 44 with tips!!!!
    So I'm looking to replace my OEM 2006 headlight assembly with new ones and either conversion to HID or LEDs. Yes I have Amazon prime. What's my best bang for my buck
  2. Dec 30, 2018 at 7:00 AM
    Gus87
    Gus87 Well-Known Member
    Chicagoland
    16 trd sport
    I am currently looking as well. Maybe bumping the thread will help.
  3. Dec 30, 2018 at 8:23 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    To run anything other than a halogen will require using projectors. Inexpensive aftermarket projectors will give poor performance, and using LEDs in them will only make it worse. See why LEDs should not be run in the OEM reflectors here:
    https://www.tacomaworld.com/threads/why-leds-should-not-be-run-in-halogen-reflectors.454371/
    If you want to run HIDs the correct way is an HID projector retrofit, designed for HIDs. But those can be very expensive.
    The correct solution if looking to boost output from a halogen reflector headlight:
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-h4-not-led-or-hid.398066/
    Norton and b_r_o like this.
  4. Jan 18, 2019 at 6:11 PM
    PErsing
    PErsing Well-Known Member
    Paul
    Southern Maine
    2012 Tacoma TX pro
    Caliraised 52" curved lightbar, Fox Shocks, TacomaBeast projector headlights
    i have leds i installed about a month ago, but i have aftermarket headlights so not sure what size you would need. i got replacement bulbs for the fogs too.
    $37 for headlight bulbs https://www.amazon.com/gp/product/B06XHDYTGL/ref=ppx_yo_dt_b_asin_title_o03__o00_s00?ie=UTF8&psc=1
    $26 for fogs (fogs are factory) https://www.amazon.com/gp/product/B075MX6TDC/ref=ppx_yo_dt_b_asin_title_o02__o00_s00?ie=UTF8&psc=1
    lights are great, 6500k pure white. no blue tint noticed.
    fogs are labled as 800 lumens, but they are just as bright as the factory bulbs.
    not sure on the headlight bulbs as i got them when i got new headlights. never tried them in the oem housing.
    the only issue is the ones i bought do not have cooling fans and they do get hot, although i have not ran into any issues yet. i decided to get these because without the fan they are small enough to fit my headlight housing without any issues of leaking due to pushing on the rubber back to seal it off.
    hope this helped. let me know with any questions.
