Headlight assembly recommendations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fox100, Sep 30, 2022.
  1. Sep 30, 2022 at 9:04 PM
    Fox100
    Fox100 [OP] Member
    Jersey
    2016 DCSB TRD OR
  2. Oct 1, 2022 at 7:48 AM
    eurowner
    eurowner Duke Sky
    Scoty
  3. Oct 1, 2022 at 8:04 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    How about using some insurance $ and retrofitting OEM LED lights from 2020+? Most of those aftermarket headlight assemblies have poor lighting performance
  4. Oct 1, 2022 at 10:40 AM
    Fox100
    Fox100 [OP] Member
    Jersey
    2016 DCSB TRD OR
    That might be a good option will they fit in the 2016 with the same mounting points cause then I'll just tell the body shop to order them, but the lighting performance can't be much worse than than the oem headlights I can't even tell if there on half the time that's the main reason I don't want them anymore, and want to go led
  5. Oct 1, 2022 at 11:47 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    They should fit the 2016 but you will need adaptors for your current OEM connectors.
    @daveeasa is the man when it comes to that.
    The 2020+ OEM LED headlights will be a better upgrade than most aftermarket headlights you find.
  6. Oct 1, 2022 at 1:23 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Believe it or not, one guy swapped his factory LED for halogen because he liked the looks better. I found that move mind boggling.
    I have a 2016 so I can say with absolute certainty what you already know, yes they fit any 3rd gen.
    Morimoto xb v2 is the only alternative assembly to consider. Read the thread @eurowner linked for full reviews and numbers. Everything you want to know is in there.
  7. Oct 1, 2022 at 5:47 PM
    Integerdy
    Integerdy Aspiring "SR5 Pro"
    Eric
    So-Lame, Oregon
    21 SR5 Silver Sky DCSB
    Hated my oem halogens. While most ppl would say go OEM LED, and I don't disagree with this, but I did go with Morimotos myself and I love them
    in2seconds and ktbell444 like this.
  8. Oct 1, 2022 at 5:58 PM
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    That's a reputable brand though. I'd trust them as well. But there are a few aftermarket brands that are just plain garbage and I'd avoid at all costs.
  9. Oct 1, 2022 at 9:07 PM
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    OEM LED via @daveeasa harness has been a great replacement for the old halogens my 2021 came with. Definitely recommend the switch
    Chew and ktbell444 like this.
  10. Oct 1, 2022 at 10:45 PM
    Dagostino480
    Dagostino480 Well-Known Member
    Colton
    2014 Tacoma TRD sport 4door
    Bad ass air freshener
    diode dynamic form lights are quality but still under $1000
  11. Oct 1, 2022 at 10:47 PM
    guest_707
    guest_707 Well-Known Member
    How would that even work? They'd need an adapter to go from LED to Halogens, right? Did the guy make his own/splice wires together or something?
  12. Oct 1, 2022 at 10:53 PM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    He needed an adapter. Dave wanted no part of it, but I have no moral hang-ups… :anonymous:
  13. Oct 1, 2022 at 10:54 PM
    guest_707
    Yes, can 100% tell by your username.
    Jk :rofl:
  14. Oct 2, 2022 at 7:58 AM
    SYVIRUS
    SYVIRUS Active Member
    Glenn
    Cincinnati
    2019 TRD Off Road 4x4
  15. Oct 2, 2022 at 8:40 AM
    Integerdy
    Eric
    So-Lame, Oregon
    t2c, eurowner, Siblue and 3 others like this.
  16. Oct 2, 2022 at 1:52 PM
    SYVIRUS
    Glenn
    Cincinnati
    This is true but i cant help with how sexy they look....
  17. Oct 2, 2022 at 2:17 PM
    Tacospike
    Two Trucks
    I don’t feel they even look cool. Make the truck look like an insect. Which kind of disgraces the entire truck. You can look at the truck from the rear, then get to the front and think, oh….. no… smh.
    I kind of like the gimmick start up sequence then feel like it’s an illusion with more engineering / programming of that one variable overlooking and entire product. To further the gimmick YouTubers (some, not all) up playing them from a visual aspect only.
    Everyones taste is different. Some go for looks. Some for function. Some both.
    I went OEM LED for both trucks. Happy with both. Also happy the tundra headlights were half the price of the Tacoma ones. Why and how idk, even with the tundra ones having leveling motors in them.
    t2c, burnttaco7 and skeletron like this.
  18. Oct 2, 2022 at 3:00 PM
    daveeasa
    David
    PNW
    Stop it, @Tacospike , I will not (repeat that to yourself every day) buy another truck just to be like you. I will not. I will not.
    So little willpower with this one...
    musicisevil and Tacospike like this.
  19. Oct 2, 2022 at 3:38 PM
    Tacospike
    Two Trucks
    <3
    Fair enough
    Do it
    daveeasa[QUOTED] likes this.
  20. Oct 3, 2022 at 9:39 AM
    Fox100
    Fox100 [OP] Member
    Jersey
    2016 DCSB TRD OR
    Thanks for all the input everyone I'll def go with the oem LEDs, so the only other thing I'll need for them is that wiring harness and then it will mount right up correct?
    musicisevil and Chew like this.
