Headlight assistance requested
Discussion in '1st Gen. Tacomas (1995-2004)' started by TruckinDumbo, Nov 15, 2023.
  1. Nov 15, 2023 at 6:42 AM
    TruckinDumbo
    TruckinDumbo [OP] New Member
    Julian
    2000 Toyota Tacoma baseline
    Standard cab automatic
    Hello group!
    I have a 2000 Tacoma baseline model with original headlights. They do not illuminate the road well and I often resort to keeping my brights on at all times. I would like to explore options on the easiest fix. Would anyone comment on if bulb change would suffice? Or would it be best to upgrade to LED? If there is an option that requires less work/energy/time that would be preferred. thanks!
  2. Nov 15, 2023 at 6:55 AM
    02hilux
    Planet: EARTH
    Don't go LED, you'll blind oncoming drivers. I enjoy using my forward facing light bar on idiots with LED/HID.
    What about installing new headlight housing?
    Dbarffish likes this.
  3. Nov 15, 2023 at 6:58 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome To TW...
  4. Nov 15, 2023 at 8:43 AM
    TruckinDumbo
    Julian
    Thanks for the response 02hilux,
    Would housing increase the wattage to the headlight bulbs? Do you think the current issue resides in the bulbs being too old? Could I just upgrade the bulbs without replacing the housing? thanks
  5. Nov 15, 2023 at 8:43 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Search here for the ultimate headlight upgrade for the 1st gens. It's a well documented process.
  6. Nov 15, 2023 at 8:58 AM
    DonB57
    DonB57 Member
    I would first check the headlight aim.
    If the headlights are significantly faded (yellowed) then new stock lights will make a big difference.
  7. Nov 15, 2023 at 9:29 AM
    Madjik_Man
    Colorado Front Range
    Everything you want to know about headlights by an incredibly knowledgeable resource @crashnburn80 : https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-h4-not-led-or-hid.398066/
    In summary:
    Buy new OEM headlight housings.
    Upgrade the wiring harness (see thread) and use whatever bulb crashnburn 80 recommends.
    If not upgrading the wiring harness buy whatever regular bulb crashnburn80 recommends in the thread.
    Kevins60 and 4xdog like this.
  8. Nov 15, 2023 at 11:27 AM
    02hilux
    Planet: EARTH
    Clarity of the lens
  9. Nov 15, 2023 at 11:37 AM
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
    Can anyone tell me how much a new OEM, non-LED, non-sequential turn w/DRL cost for a 2022 TRW-Sport? I'm talking the whole assembly including the outside lense?
    Something is strange about the parts online. I can't enter my VIN anymore to have it qualify the part is compatible? Anyway, there seem to be a few variants of headlamps.
  10. Nov 15, 2023 at 12:17 PM
    02hilux
    Planet: EARTH
    Wrong section
    50Buck likes this.
  11. Nov 15, 2023 at 1:18 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    HID retrofit in some ebay housings.
    EDIT: jesus christ I've posted 10,000 times on this forum.
    Xperivent likes this.
  12. Nov 15, 2023 at 3:29 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    you can always get a kit and redo the front of the lenses to remove the dingy yellowed film. Then spray some clear coat on the lenses. Or just buy some new headlights from you favorite parts store and install some new bulbs if they don't come included.
  13. Nov 15, 2023 at 3:42 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I tried many kits over the years, and have experience buffing paint and other items out. No matter what product or protective coating, the lens oxidize again. Further, the lens' just break down over time and defuse the light even after a fresh sand/polish/protective coating. At 20+ years old that plastic just needs to be replaced. The TYC certified housing on rock auto are a great alternative to the OEM product. Just those new housings and bulbs will make a huge difference without the wiring kit and fancy bulbs.
  14. Nov 15, 2023 at 3:59 PM
    THatt
    THatt Well-Known Member
    Upstate SC
    1996 Tacoma 2.7L MT 4X4
  15. Nov 16, 2023 at 2:18 AM
    stftaco
    Fair enough.
  16. Nov 16, 2023 at 6:08 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
