Headlight bulb replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BeefedTacos, Sep 26, 2019.
  1. Sep 26, 2019 at 10:49 AM
    BeefedTacos
    BeefedTacos [OP] Well-Known Member
    Brian
    North Carolina
    2015 tacoma dcsb SR5 4x4
    None so far
    Really want a good light output and a cool white color. Any recommendations? Sorry if there’s been past threads
  2. Sep 26, 2019 at 11:06 AM
    TXTaco211
    TXTaco211 Well-Known Member
    Corpus Christi, Tx
    13 Pyrite Mica TRD Sport DCSB
    Kicker Speakers, 5100's with HS coils and HS AAL, Caliraised 30" LED light bar
  3. Sep 26, 2019 at 11:10 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    END THREAD////
    crashnburn80 and Norton like this.
  4. Sep 26, 2019 at 1:30 PM
    BeefedTacos
    Brian
    North Carolina
    None so far
    They discontinued that bulb. Any other good ones?
  5. Sep 26, 2019 at 1:38 PM
    Muddinfun
    Muddinfun Well-Known Member
    pinktaco808 likes this.
  6. Sep 26, 2019 at 1:40 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    pinktaco808 and Norton like this.
  7. Sep 26, 2019 at 2:51 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    It's obvious you didn't even read the first post of the thread, where at least three currently available bulbs (i.e., OSRAM Super Bright Premium High Wattage Headlight Bulb 9003, Philips RacingVision 9003, and GE Lighting H4 NHX/BP2 Nighthawk Xenon) are recommended.
  8. Sep 26, 2019 at 5:58 PM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    I just did the harness and bulbs as advised in the ultimate upgrade thread. They are "still" available on line. Great and worth while up grade. The Caliraised light bar I also added was a mind blowing up grade... white too.
  9. Sep 26, 2019 at 9:25 PM
    BeefedTacos
    Brian
    North Carolina
    None so far
    Originally wanted a LED looking white/blue. I briefly read and came to the conclusion blueish tint is unwanted for output and oncoming traffic.
    Norton likes this.
  10. Sep 26, 2019 at 9:43 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    I run Sylvania Silverstar ultra ZXE in my truck and my wife’s CRV. They have great cutoff and they are bright and white in color. Been on both vehicles for about 2 years.
    TRDRACER likes this.
  11. Sep 26, 2019 at 10:10 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Halogens produce lots of yellow light and little blue light. Blue filters to make a halogen white/blue-ish work by removing the yellow light and only allowing blue light to pass through, or in other words, removing the bulk of the output so the minority of the output can make the color look white/bluer. That kills light output. Look at the charts in the thread, I've provided all the data for actual real performance bulbs (not cosmetic ones) so you can pick the whitest looking bulb based on the data and see what kind of output performance you'll have and strike a balance that works for you. LEDs in an H4 reflector housing are just going to cause blinding glare, lots of scatter, and loss of performance.
    Too Stroked and Norton like this.
  12. Sep 26, 2019 at 11:45 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Lots of choices and when I ordered new headlights at Headlight Depot got the Perde Solar Series Platinum H4s for like $25 a pair and they are 6k white light so crisp white but not blinding. Been in 3 years now no issues. Look them up if interested.
  13. Sep 27, 2019 at 7:53 AM
    pinktaco808
    pinktaco808 Hot Steppa
  14. Sep 27, 2019 at 7:53 AM
    pinktaco808
    What the brightness color?
  15. Sep 27, 2019 at 9:15 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The brightest (low beam) and whitest stock wattage bulb is the Philips Racing Vision +150 which is 3600k. If you are looking for 5000k in a 2nd Gen reflector there are no good options other than retrofit. There is a 100/90w Osram Cool Blue 5000k bulb. You will need a harness from the linked thread to run it. Output will be substantially less than the uncoated bulb, and the bulb will run extra hot due to the coating leading to shorter life. Not a solution I would recommend.
  16. Sep 27, 2019 at 11:40 AM
    zdski
    zdski Well-Known Member
    Zach
    Phoenix, AZ
    2011 DCLB TRD Sport
    5100s, AAL, TRD Wheels, 285 Ridge Grapps
    I second this choice. I picked up the same ones from AutoZone about 9 months back and have loved them. Nice pure white and VERY bright.
