Headlight bulb upgrade
Discussion in '2nd Gen. Tacomas (2005-2015)' started by John1234, Apr 7, 2024.
  1. Apr 7, 2024 at 7:16 PM
    John1234
    John1234 [OP] Member
    Okay, I just got a 2009 5 speed Tacoma, and the headlights are pretty dull. I’m going to refinish the assembly surface, but I was wondering if I can get leds to replace the halogens, and if so, what is the cheapest decent pair of headlight bulbs yall know about? I’m not looking to replace the whole headlight assembly, that’s my main concern.
  2. Apr 7, 2024 at 7:33 PM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Oh boy...
    Taco_NW likes this.
  3. Apr 7, 2024 at 7:45 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Do NOT put LED into the standard housings! You will blind the fuck out of everyone at night.
    Taco_NW, DocJ, Watermallon and 3 others like this.
  4. Apr 7, 2024 at 8:53 PM
    Watermallon
    Watermallon ID Tacooo
    Zach
    Idaho
    2006 TRD Sport
  5. Apr 7, 2024 at 10:16 PM
    TacoTuesday1
    FL
    Headlight services harness recommends trying a certain bulb that doesn’t require the harness if you don’t want that. The caveat is it doesn’t last as long. That’s an option. I think Philips makes it. Extreme vision or something like that. Double check.
  6. Apr 8, 2024 at 10:10 AM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    These are noted in "the ultimate headlight upgrade" and are available.
    https://www.powerbulbs.com/us/product/osram-super-bright-premium-h4
    https://www.amazon.com/OSRAM-62204S...GQdg-gdFgvHHg_e5d_tPSc3yb1aGRWc8aAoQYEALw_wcB
    When I replaced the headlight assemblies "buckets" on my 07, these bulbs were included. I do very little nighttime driving so I can't give a first hand it's the best bulb ever testimony.
    From what I've read;
    1) halogen bulbs will dim with usage.
    2) brighter burning bulbs have a shorter life. As noted by @TacoTuesday1
  7. Apr 8, 2024 at 10:16 AM
    TacoTuesday1
    FL
    I mean the Osrams are probably good
    I might’ve got Flosser higher power the first time as it was cheap, available, and good quality.
    Good to keep a spare set in the truck in case one burns out to be ready wherever you are. Which they don’t seem to do often.
    supposedly there’s a good particular bulb for more performance that doesn’t require harness upgrade like these higher wattage ones, if anyone doesn’t want to do the harness for whatever reason.
  8. Apr 8, 2024 at 10:35 AM
    skee
    skee Well-Known Member
    North Coast, CA
    2006 Tacoma TRD 4x4 Access Cab
    If you go on rock auto they have quite a few options for our trucks headlamp bulbs, and they specify whether they are brighter, longer lasting, etc. I have had good luck with the “Hella” brand bulbs that were both brighter and longer listing. Definitely do not do LED.
    DocJ and BlkDakDave like this.
  9. Apr 8, 2024 at 10:55 AM
    BlkDakDave
    David
    CC TX
    AMEN Brother!
    DocJ and Taco_NW like this.
