Headlight bulbs burning out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PzTank, Dec 26, 2023.
  1. Dec 26, 2023 at 3:43 PM
    PzTank
    PzTank [OP] Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Hey 2nd Gen folks,
    My ‘15 AC has blow two bulbs on the passenger side within about a month. Drivers side is fine.
    Stock set up using Sylvania bulbs. No LEDs, no mods whatsoever to the electrical system.
    Any thoughts on diagnosing?
    Any thoughts on anything else related :D
    TIA
  2. Dec 26, 2023 at 3:47 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    I saw a little moisture in one of my housings prior to freeze up. Changed both rubber boots & haven’t seen any more yet. I’m thinkin’ moisture…..:notsure:
    PzTank[QUOTED][OP] likes this.
  3. Dec 26, 2023 at 3:48 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Has to be contaminated or just bad luck. Any chance you touched the bulb or it got wet?
    passenger side is a pain to get at, my guess is you touched the bulb to something
    SR-71A, bgavin and PzTank[OP] like this.
  4. Dec 26, 2023 at 3:49 PM
    PzTank
    Above the Notches
    Thanks :thumbsup: I haven’t noticed any moisture but will check more closely in the ‘morn.
  5. Dec 26, 2023 at 3:49 PM
    TacoTuesday1
    SD CA
    is water getting inside
    The lens should be sealed and some folks put a pack or two of silica gel hidden inside. Not sure if there’s moisture drain tubes; headlights usually do.
    Are you touching the bulbs barehanded getting oil on them to cause premature failure
    are the electrical connections there firmly seated, tight not worn out, and in good condition without corrosion
    what condition is the housing in
    are the bulbs from a legitimate source not counterfeit
    and not dropped or impacts causing internal breakage
    If it was me I’d either have replaced housings, ceramic harness, better bulbs
    Or those other good bulbs that claim to achieve similar effect without the need for harness
    Anything else I wouldn’t be wasting time on
    PzTank[OP] likes this.
  6. Dec 26, 2023 at 3:55 PM
    PzTank
    Above the Notches
    I had gloves on when I installed :notsure:
    I find the passenger side easier than the driver’s side and the last change went smoothly.
    I didn’t clean the connector though and the dielectric gease was piling up. I’m thinking of a bed of paper towles underneath and hitting it with some electrical cleaner. Maybe adjust the terminals if they look flat…
  7. Dec 26, 2023 at 3:59 PM
    TacoTuesday1
    SD CA
    electrical cleaner spray can is a good thing to have.
    idk about dielectric grease. Supposedly too much can be bad. There’s definitely other good products out there. Including deoxit.
    though I did use some on my tow connector because it’s really exposed and outside contaminants tend to try and work their way into there on any truck.
    Connector work is tricky regarding special tools to scuff up pins, make sure they’re not fatigued out of position, and inspecting the connector seal is good.
  8. Dec 26, 2023 at 4:25 PM
    PzTank
    Above the Notches
    I always have electrical cleaner on hand!!
    Thanks for the heads up on Deoxit :thumbsup: I’ve always used a dab of the dielectric with no issues but I’m willing to try something else.
    Also, unless O’Reillys, the major auto parts store in these parts, is selling counterfeit parts, I’m pretty sure they’re legit.
  9. Dec 26, 2023 at 4:29 PM
    Waasheem
    Waasheem
    2007 xrunner
    You might have got some of that grease on the glass part. If there’s too much grease, it could leach over to the glass. Clean the excess, try again.
  10. Dec 26, 2023 at 4:37 PM
    PzTank
    Above the Notches
    Good point, thanks!
    I installed the bulb, wearing gloves only touching the tangs, install the boot, then dab the grease before I put on the connector.
    The boot and connector are in good condition.
    FastEddy59 likes this.
  11. Dec 27, 2023 at 10:54 AM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    We’re the bulbs from the same package?
  12. Mar 8, 2024 at 12:05 PM
    Mikesinreach
    Mikesinreach New Member
    2013 Tacoma access v6 4wd pyrite mica
    LEDs, tonneau bed cover, SONY ax4000, CarPlay, console, rear under seat locks on boxes
    Replaced headlights w/sylvania H1 the started getting moisture in both lenses. Used hairdryer to create Venturi suction and removed moisture. Vaselined the boot. Still gets moisture inside. Center hole was too small in boot to go around bulb’s fan so had to enlarge it. Fan sucks out air from enclosure but not enough to remove moisture. Seems a tight seal around fans. Then noticed 2 small orange gaskets included in box with bulbs.. no mention of them in install manual. Where’s this water coming from (it happens in the rain). Anyone have this problem?
  13. Mar 8, 2024 at 12:16 PM
    Mikesinreach
    Hyperflash fixes! Wanted to have DLR for safety. DLR choice is in lights stalk, not does nothing on the 2013 access cab. Installed LED with white and amber output (DLR and turn signal) and amber LEDs in tail fixtures: hyperflash resulted Neither style bulb has resistor (“can-bus”) built in so flash control module thinks a bulb is burned out and flashes fast so you (and police) know you’ve got a burned out incandescent bulb. (This is because the LED draws such little power). Dealer wants, get this, $260 to unplug and plug in specially designed LED flash module located impossibly under the dash, behind the fuse box (e.i. Labor!!). Lessons: make sure turn signal LED bulbs have built in resistors so it doesn’t fool the module to think it’s a burned out incandescent or expect a whopping labor cost to install a LED specific module that just plugs into the original 8 pin (2013 Tacoma) connection.
  14. Mar 8, 2024 at 12:31 PM
    Mikesinreach
    I’m installing LED turn, DRL in the little triangular space next to head lights. These are white LEDs for DRL and then produce a cascading effect of amber LED’s with turn signals. One must remove the front grill to install this product which sells between $40 -$100 on eBay/Amazon. I hooked the turn signal leads to the existing wires that go to front turn signals using clamp on connectors from Autozone. I attached the DLR lead also to other lead going to the front turn signal bulbs that come on with parking lights. When I turn on my headlights, this new addition turns solid white. Still havent figured out to have white DRL from this new addition. Replaced front “side marker” lights from amber to white LEDs. Now All these come on white with head lights. But dual function (white and amber) turn signal front bulbs and added “dual function cascading turn and DLR units” all are amber for DRL. I want all white for DRL without turning on headlights? How?
