Headlight bulbs keep blowing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ryanbitt, May 19, 2016.
  1. May 19, 2016 at 8:46 AM
    ryanbitt
    ryanbitt [OP] Wherever you go...there you are.
    Hutto TX
    07 DCLB 4x4
    Wouldn't you like to know!
    In the past 6 months to a year I have replaced my headlight bulbs about 6 times or so and more recently I have replaced them 3 times in the past few months(I've been keeping an extra pair in the truck just in case now). Not quite sure what the problem could be but my whole front end is stock on a 07 DC. I've looked at the connectors and they don't look the best, pretty grimey and dirty. Also I have been using sylvania silverstars the whole time. Any help is much appreciated.
  2. May 19, 2016 at 8:47 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I would clean the connectors and put a little dielectric grease on the them. Might help.
  3. May 19, 2016 at 8:51 AM
    ryanbitt
    Hutto TX
    07 DCLB 4x4
    yeah I get that, but the last pair I bought barely made it a month and the ones before that not even 2 months. Luckily Wal-Mart is nice enough to return/replace them. Also it's not always both lights that blow, sometimes its one or the other but eventually they will both blow.
  4. May 19, 2016 at 8:55 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    I didn't read the post carefully the first time. Your bulbs should be lasting longer than that even if they are Silverstars. I know here at the Chevy dealer that I work at, the Trailblazers were having trouble with headlight bulbs blowing out and new connectors solved the problem.
  5. May 19, 2016 at 8:55 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    So..
    Or you have a wiring problem.
  6. May 19, 2016 at 8:56 AM
    T4RFTMFW
    My Silverstar Ultras last 2 years+.
    JimboAnz likes this.
  7. May 19, 2016 at 8:56 AM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    Clean the connections and make sure you are not touching the glass with your bare fingers. is there possibly water in the housing?
  8. May 19, 2016 at 8:56 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    I need to try some new bulbs, still running stockers :anonymous:
  9. May 19, 2016 at 8:58 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    I've never used the Ultras. I may have to try those next time, because I couldn't get 6 months out of the regular ones. The light output was nice, though.
  10. May 19, 2016 at 8:58 AM
    T4RFTMFW
    I love Ultras.
    Currently running some PIAA I got to test and not really pleased with them. Looking forward to them blowing out so I can go back to my old reliable. Been running Silverstar/Silverstar Ultra for over a decade on every vehicle and never had a premature burnout.
    JimboAnz[QUOTED] likes this.
  11. May 19, 2016 at 9:01 AM
    T4RFTMFW
    Everyone on this forum says they suck and they don't last 2 months.
    But my Tacoma ran its set for 2 years. My Chevy ran its set for double that, and the second set was as old when I sold it and they were still doing great. Both of my Scion's had Silverstar headlight and fog light bulbs and no issues on either.
    I love them. Carefully installed with gloves and making sure I'm not bumping the bulb into things when I install them.
    No problems. Ever.
    Red Baron and NAAC3TACO[QUOTED] like this.
  12. May 19, 2016 at 9:04 AM
    TacoMan33
    TacoMan33 The little idiot that could
    David
    Texas
    2006 PreRunner 4.0 V6 SR5 ACLB
    JBA C/B | Apline door speakers | Kenwood radio
    Clean the connectors, replace the fuses for your headlights, and check the wiring. Some of that grease mentioned earlier should help. Your bulbs shouldn't be going out like that
  13. May 19, 2016 at 9:09 AM
    ryanbitt
    Hutto TX
    07 DCLB 4x4
    That is where I will start most definitely, I usually don't use gloves just try to be as careful as possible but from now on I will use latex gloves.
  14. May 19, 2016 at 9:12 AM
    ryanbitt
    Hutto TX
    07 DCLB 4x4
    I've never seen water in the housing, but I will clean connectors up real good and replace the fuses and install the next set with gloves just to be sure.
    Red Baron[QUOTED] likes this.
  15. May 19, 2016 at 9:12 AM
    TacoMan33
    David
    Texas
    Gloves are a good idea, but if you don't like gloves (like me) then simply disconnect the negative terminal of your battery and place it where it wont accidentally reconncect
  16. May 19, 2016 at 9:14 AM
    Pigpen
    Dan
    Northwest Montana
    The gloves are to keep the bulb clean. A fingerprint, even from a "clean" hand will greatly reduce the life of a bulb.
  17. May 19, 2016 at 9:19 AM
    Red Baron
    Aaron
    07 Radiant Red DCSB
    ^^ what he said from the oils on all of our fingers
  18. May 19, 2016 at 9:20 AM
    T4RFTMFW
    Wut
  19. May 19, 2016 at 9:21 AM
    T4RFTMFW
    To add, any oil or grease, and any scratches.
    Pigpen[QUOTED] likes this.
  20. May 19, 2016 at 10:32 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Just to make sure someone didn't have a bad day in the manufacturing plant, should you clean brand-new bulbs before install? If so, clean them with what??
