headlight bulbs
Discussion in 'Lighting' started by brant_trd, Jul 30, 2007.
  1. Aug 6, 2007 at 7:32 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    glad to hear it worked out for you, i may have to grow a pair and give it a try sometime soon
  2. Aug 6, 2007 at 8:24 AM
    wormhole7
    wormhole7 Well-Known Member
    Lake Dallas, Tx
    TSS
    Leather, Suspension TSB, Billy 5100's up front set at .85, Eaton Posi LSD,Grillcraft Black Mesh Grills,Aires Bull Bar,Black Low Profile Narrow Toybox,Black Headlight Mod,Black Tail lights ,USA Spec,Ipod, PopnLock,Bed Mat,Bug Sheild,Vent Visors, Weathertec Liners,Radar,Nuvi 760,Dog Ramp,Convex Mirrors, Roof Rack, Tint, Borla exhaust, Borla Intake, OBX pedals, Home Link Auto Dimming Mirror with remote, 20" Factory Wheels, Factory Tube Steps
    Well, in all fairness, I was kind of stumped as to how to get just the chrome piece out after the lights were apart. I saw the two hex screws but it was my girl friend who noticed the little tabs (2) that you had to pop before the two pieces would separate. So probably thanks to her I didn't get frustrated and break the darn things. Guess I should consider getting some glasses, cause I didn't even see em.
  3. Aug 6, 2007 at 1:21 PM
    The_Hodge
    The_Hodge They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    i put in my new "HID" superwhites in the truck today. i'll post tomorrow after i drive home tonight and tell yall what i think. from what i've seen during the day, they look quite bright and white.
  4. Aug 6, 2007 at 1:56 PM
    wormhole7
    Lake Dallas, Tx
    TSS
    When changing the lamps (bulbs) do you have to take the headlights off?
    When I had mine off I really couldn't tell how to get them out, though I didn't really spend much time seeking an answer to that end. And I would be curious as to how much difference you can tell with the new lights setup. If the difference is dramatic, I'll add it to my wish list.
  5. Aug 6, 2007 at 2:26 PM
    The_Hodge
    SC
    you dont have to...the passenger side one is harder to get to b/c of the wiper tank...i think...but it is possible to change them w/o taking them out. thats the way i did them today
  6. Aug 7, 2007 at 12:13 AM
    The_Hodge
    SC
    ok...well from what i can tell, the new bulbs dont seem to have the range of the stocks ones...but i do love the white view and how it looks from the outside. i think i'll be keeping them in anyways...sometimes u just have to sacrafice for looks...lol
  7. Oct 5, 2007 at 10:41 AM
    smile_geoff
    smile_geoff New Member
    Hello I installed an HID Xenon Kit on my Tacoma 1998
    It was a H4 low Xenon bulb with a quartz halagon high beam bulb. 5000K was the color as I wanted it to be simular color to my Sylvania SilverStar bulbs (4300K).
    http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=280157807834&ih=018&category=36476
    This supplier had good prices and fast delivery.
    What I did not like about this kit was
    1) Wiring plugs were backward. IE which way wires came out of rubber sealing ring. The HID wires were correct, but the quartz wires where backwards. I pulled on the white wires for high beam and one of them came out of connector in my hand. This was the double wire for common light ground connection going to the 3 terminal connection for plugging into existing headlight plug socket. But I need to fix this anyway. So little work opening other crimp on connectors that plug into existing headlight wiring. Some soldiering and that was done.
    2) Mounting of passagerside ballast was easy. Found metric bolt to install in empty welded nut that Toyota gave me on fender just back from aircleaner. Drivers side required me to drill and make my own mounting hole very near RAD support. As I have just to many things on drivers side by battery. Block heater cord,120V Battery blanket, and 120V Electrical receptacle to plug cord ends in.Also I have battery isolated and resetable breakers for trailer feed on fender between battery and fuse box.
    3) After disabling DRL took 2 attempts,First attempt remove DRL fuse from engine bay fuse box. Second attempt Finally I unpluged dropping resistor on drivers side between battery and fender.
    4) Install lights and did burn in test.
    5) Now what I do not like... (Buy biXenon instead of Dual bulb) .... My bulbs have 1 HID Xenon bulb for low beam. Takes upto 4 seconds to get good and bright.But when you switch to high beams Low Beam Xenon bulb goes out and now you have crappy quartz halagon bulb for high beam. My old Sylvania Silverstar bulbs are a lot brighter that high quartz halagon bulb. Now the problems comes when flipping back to lowbeam, Lights take up to 4 seconds to get good and bright..... but when they are finally lite man are they bright.
    I think I would buy this BiXenon kit instead.
    http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=280138852124&ih=018&category=36476
    Then would not have to worry about 4 second bright turn on time, and not have to worry about crappy quartz halagon bulb.As I want to be able to see deer jumping in front of my truck instead of smacking them with my truck.
    Quartz Halagon bulb is in a replacable socket so I am trying to find Sylvania replacement.No luck yet as I do not know bulb type.
    Just hate to part with another 100+ dollars for BiXenon light because I made a mistake.
  8. Oct 5, 2007 at 11:36 AM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    :eek:I got news for you, before you buy that ring is the only time you really have the freedom to buy whatever the f*** you want...no matter how stupid. I find myself sneaking a few online purchases every year just to make me feel better.
  9. Oct 5, 2007 at 11:44 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    Ditto - minus the sneaky purchases. I have no freedom with my money. :(
  10. Oct 5, 2007 at 11:45 AM
    lsocoee
    Hotdog
    Wet Okole Underwear
    Occasionally I feel guilty about the sneaky purchases. I find that what helps me get over it, is buying something else.
  11. Oct 5, 2007 at 1:05 PM
    sawdust
    sawdust Unapologetic Texan
    Frisco, TX
    07 TRD Offroad Radiant Red V6 Auto DC
    Homelink mirror, tailgate lock, 2ndary air filter removal, Access LE tonneau, Bugflector II, hitch-based bed extender, vent visors, suspension TSB, stall mat
    Just explain that the new cat-back exhaust system is just as important to you as those new fashionable high dollar shoes (or whatever floats her boat) are to her. Both of you need your little financial indulgences.
  12. Oct 5, 2007 at 6:49 PM
    wormhole7
    Lake Dallas, Tx
    TSS
    Come on guys, I thought you were supposed to provide "SUPPORT". I'm starting to get "frightened". :p I keep telling her that it's just a friggin rock, nothing more. She ain't buying in to it though. :D
  13. Oct 5, 2007 at 7:23 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    You just have to spin it right. I told my better half that is was BS that I had to buy her a rock, but I didn't get anything. I explained to her that from hence forth all engagement rings would have to be equalled by her purchase of an engagement car of equal value. In my case a 1988 Fiero Formula. (In halfway good shape about the same price as the ring she wanted). Needless to say, she saw my point and I lack a Fiero, and she lacks an engagement ring, and we both just wear wedding bands.
    Disclaimer... This was the second marriage for both of us, so if you and her are still on your first, your results may vary.
  14. Oct 5, 2007 at 8:10 PM
    wormhole7
    Lake Dallas, Tx
    TSS
    I like that. Mind if I use it?:p
  15. Oct 5, 2007 at 10:28 PM
    #35
    maverick491
    South Jersey
    Go right ahead. Like you said we are supposed to provide SUPPORT. :)
  16. Oct 6, 2007 at 9:51 AM
    #36
    wormhole7
    Lake Dallas, Tx
    TSS
    You rock Maverick. It actually worked :D. Too cool.
    Did it just as you described. Told her if I was going to get her a rock, then she should get me something of equal value. She kind of scared me momentarily, and said, "like what" :eek:. The only thing I could come up with on the spot was " a high end laptop". Then she said, OK, we'll just do wedding bands. WOOO HOOO:D
    Thanks bro....
  17. Oct 8, 2007 at 9:58 AM
    #37
    nd
    Nate
    Greenville, SC
    Maverick..... dude..... i have never had so much respect for anyone from Jersey before as i have for you. That is such a great idea! From now on thats what i'm gonna tell my womens. Why the hell do they get a multi thousand dollar ring i get nothing? and on top of that, when you register for wedding presents its always for lame stuff at lame stores. And on top of that, the women also get your balls. What kind of shithouse deal is that?!?! Men must be the dumbest creatures on the planet. We basically pay women (with a ring) to boss us and nag us for the rest of our lives and get nothing in return.
    All i know, when i get married, i'm registering at Best Buy, Grady's outdoor shop, Circuit City, porn/lingere shops, liquor stores, and the Toyota Parts Department. When people ask who makes my wedding china i'm gonna say "solo".
    But seriously Mav, that is great thinking. i want an "engagement wench" for my taco when i propose.
  18. Oct 8, 2007 at 11:52 AM
    #38
    maverick491
    South Jersey
    ND, I am honored to be respected by you. I am kind of curious though do you actually know anyone else from Jersey??? :p
    I am pretty sure that you have a much better chance of getting an "engagement w"I"nch" when you propose. Unless by "engagement w"E"nch" you mean that you'll get her to dress like this for you all the time.
    In which case that wouldn't be a bad deal either. :)
  19. Oct 8, 2007 at 1:16 PM
    #39
    nd
    Nate
    Greenville, SC
    Ok, so we concluded that there is a big difference between the wench and the winch. Anyway, i want the Winch. I do know one other guy from Jersey and i actually like him alot
  20. Oct 8, 2007 at 1:52 PM
    #40
    WildcaTaco
    WildcaTaco Well-Known Member
    06 Access Cab V6 TRD Off-Road PreRunner
    Removed Secondary Air Filter
    I want both:wink:
