Headlight clear covers...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Larry, Aug 11, 2012.
  1. Aug 11, 2012 at 5:15 PM
    Larry
    Larry [OP] CARL
    CARL
    Anyone install these?
    just got a set delivered via fedX. may do the install tomorrow.
    any install tips?
    thanks.
    Rambo54 likes this.
  2. Aug 11, 2012 at 5:27 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Nope but I'm interested to see :popcorn:
  3. Aug 11, 2012 at 5:29 PM
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    I've heard a hair dryer / heat gun helps and clean the hell out of your headlights before installing.
  4. Aug 11, 2012 at 8:32 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    I have always been curious about ... how well the covers work ... and FL sunshine will be a good test.
  5. Aug 11, 2012 at 8:34 PM
    SOSHeloPilot
    2024 4Runner SR5
    ... ^^^ ... A little scrubbing with 80 grit should do the job. ... :eek: ... :D
  6. Aug 11, 2012 at 8:43 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  7. Aug 11, 2012 at 9:45 PM
    brianv3ntura
    brianv3ntura Well-Known Member
    Jacksonville FL
    MGM'12 Taco TRD Sport 4x4 DCLB 4.0L 5spd Auto
    Stock for now.
    To me,, this is a big waste of money. just routinely clean,polish, and wax the headlights. the film will end up hazing and yellowing later.
    1) clean the headlights. since its a '12, it shouldnt be that bad.
    2) personally i wouldnt use a heat source until install is done. stretching using heat is bad in the long run.
    3) make sure youre in a dust free area. dont want dust to get under the film.
    4) i would spray a diluted solution of soapy water. a light coat...enough to move the film around instead of testing your luck and have it fit the first time.
    5) use a hair dryer or heat gun to dry.
  8. Aug 12, 2012 at 6:45 AM
    Larry
    Larry [OP] CARL
    CARL
  9. Aug 12, 2012 at 6:50 AM
    Larry
    Larry [OP] CARL
    CARL
    owners manual specificaly says not to use way or polish onthe clear headlamp covers. :notsure:
    The instructions say to use a 1/3 ratio alcohol/water soultion. I have done other vinyl lettering in the past and used our method of diluted soapy water.
    the instructions also suggest heating the headlamps (buy turning them on) for a little...and using a blow dryer as heat sourse to work the edges...
    may be why others have had pucker problems on the corners?
