Headlight condensation
Discussion in 'Lighting' started by mcdowell, Jan 13, 2012.
  1. Jan 13, 2012 at 8:38 AM
    mcdowell
    mcdowell [OP] My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    This is how Range Rover deals with light condensation. The 2 tubes you see on the back of the lights are holes in the housing. One hole on the bottom lets in air and the hole on the top exhaust the air and condensation out. Tubes are connected for off road use and water will not flood in. This will help anyone who has done the BHLM having issues. It helped me.
  2. Jan 13, 2012 at 12:28 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    thats a good idea but, who is going to remember to connect their headlight hoses when they go off road or when it rains for 5 days lol.
    the 2nd gens have vent on them as well same principle one on the bottom and one on the top although i don't think they are nearly this open to the elements.
  3. Jan 13, 2012 at 12:33 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    intake when i took off my factory stuff it was lower than i thought it was i'm so happy i have the snorkel now.
    headlight breather mod might be a good idea though actually not kidding a one way valve like our diffs have.
  4. Jan 13, 2012 at 1:11 PM
    mcdowell
    mike
    mobile al
    2011 prerunner SR5
    The hoses stay on. Kinda dangle
  5. Jan 13, 2012 at 1:21 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    It would be effective if you could have one hose up and out of the water (or somewhere sucking dry air) and one connected to a vacuum. That would eliminate water build up entirely, almost like a mini defroster for your headlights.
  6. Jan 13, 2012 at 1:42 PM
    Pugga
    Massachusetts
    I don't have any more of those breathers... My fog light housings are sealed up tighter than a termites butt hole :cool:
    Screw headlight breather mods, if you seal the lights correctly, you shouldn't have condensation issues. Maybe if you submarine your truck constantly enough and keep getting water in them, then run run a hose from the breather holes to the inside of the cab or seal them up permanently.
  7. Nov 4, 2013 at 1:59 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Condensation without any off roading or rain... just started on my passenger headlight only. Running highbeams in the day drys it, but it condensates again the next morning. Never happened before on this 2010 or my 2005..?
  8. Nov 4, 2013 at 3:13 PM
    primer
    primer Well-Known Member
    T
    OK
    06 SS Mica AC 4x4 TRD Off-Road
    (Mostly) debadged, Homelink mirror, Elevated rear diff breather, LED illuminated 4x4 switch, Color matched grill surround, Bed cover, Ivan Stewart wheels, Bridgestone 265/75 Dueler AT Revo 2 tires
    I am somewhat confused about this issue.
    My headlights have some condensation post BHLM. Not often or terrible, but it is there. I was going to reseal them. But looking at the back there are definitely open vents. So how can it really matter that I left a pin hole somewhere that allows humid air in and out. If I seal that I will still have much more area for air to flow in/out in back...
    TL
  9. Nov 4, 2013 at 4:09 PM
    David K
    I don't know what a BHLM is, but these are halogen lights, not sealed beam, so they might need an open vent to not condensate? Perhaps the vent on my passenger side lamp is clogged? Photos of where this vent is would be great...
  10. Nov 4, 2013 at 4:14 PM
    primer
    T
    OK
    Black HeadLight Mod...
    I'll try to grab a pic.
    TL
  11. Nov 4, 2013 at 4:27 PM
    David K
    Thank you!
  12. Nov 20, 2013 at 4:23 PM
    David K
    Found a black rubber cap (with a white round sticker) covering a hole into the back of the headlamp housing. Inside the rubber cap is a filter... I could not detect any clog, dirt or reason why the one lamp gets filled with condensation... but I removed the plug and will check the light tomorrow.
    I did not see anything different top and bottom?
