headlight dimmer relay issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by poppahank, Jan 28, 2016.
  1. Jan 28, 2016 at 1:39 PM
    poppahank
    poppahank [OP] Member
    henry
    2004 tacoma prerunner
    I have a 2004 prerunner and have a dimmer relay issue. I have no bright lights, I changed the dimmer relay and everything was good - for 1 1/2 days. no bight lights again. I changed out the headlight switch prior to see if it was bad and it was no different. I replaced the original headlight switch and put new relay in, worked for the day or about 5-8 tests.
    Any ideas on this problem?
    Poppahank
  2. Jan 28, 2016 at 1:50 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Do you have any non OEM lights? If you are burning up the relay it could be because you are pulling too much current through it... Could be a bad ground, something causing either a short or an open somewhere. Get a multimeter and start testing things.
  3. Jan 28, 2016 at 1:54 PM
    poppahank
    henry
    no after market additions. I checked lights, and power to plug. Any hints on testing the ground on this plug or relay plug would help. All fuses are good.
  4. Jan 28, 2016 at 2:04 PM
    ClevSix
    IL/IA
    I don't have a wiring diagram, maybe someone else can jump in to help with that. Basically you want to test each connection starting with the most likely cause or follow the flow of electricity from the fuse box to ground.
