Headlight + Fog light question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mmccoy6705, Mar 7, 2016.
  1. Mar 7, 2016 at 9:41 AM
    mmccoy6705
    mmccoy6705 [OP] Active Member
    Michelle
    Howard County, MD
    '15 Toyota Tacoma Sport pkg
    I have a headlight out, around the same time as the bulb burning out, both fog lights refuse to turn on.
    Is there a connection between the headlights and fog lights working or do I have two separate problems?
  2. Mar 7, 2016 at 11:07 AM
    mmccoy6705
    Michelle
    Howard County, MD
    so, quick update... took my headlight bulb out and the connector is melted!!! :annoyed:
  3. Mar 7, 2016 at 11:11 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    That doesnt sound good....stock bulbs?
    scottalot likes this.
  4. Mar 7, 2016 at 11:18 AM
    mmccoy6705
    Michelle
    Howard County, MD
    I bought a new headlight assembly, so to answer your question; the bulbs are stock in regards to they're the bulbs that came in the assembly.
    2015 Tacoma's have an H4 HB2 stock bulb, but the bulb that came in the assembly was an H9. The manufacturer stated that the assembly was PnP, which it was, but I've never had so many electrical issues in my life. haha
    ChadsPride[QUOTED] likes this.
  5. Mar 7, 2016 at 12:33 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    so you bought a crappy aftermarket assembly and it melted ?
    Jimmyh likes this.
  6. Mar 7, 2016 at 12:56 PM
    mmccoy6705
    Michelle
    Howard County, MD
    I've never had any issues with Anzo, this will be my first. But yeah, basically.
    I ordered a new assembly, it can be fixed, just have to swap out my headlights.
    I bought Spyder... so hopefully they won't be a pos.
    Quick update: the melt down must have blown a fuse, replaced fuse and my fog lights are operational again.
    My truck just keeps blowing leds left and right. My right led fog blew (this will be led #4)... sooo back to halogen.
    Is anyone else's truck rejecting leds as much as mine?
  7. Mar 7, 2016 at 1:10 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Seems it would be cheaper to stick with the Halogens. That actually work.
    Oh and the right headlight low beam fuse supplies power to the fog lamp relay coil for both fog lamps.
    mmccoy6705[OP] and McTeague like this.
