headlight fogged.. Replace it?? If so, need advice..
Discussion in 'X-Runners' started by MacyHastings, Nov 22, 2010.
  1. Nov 22, 2010 at 4:26 PM
    MacyHastings
    MacyHastings [OP] New Member
    Macy
    California
    06 X-Runner V6
    Hello all!
    First things first, I own a jet black 2006 Toyota Tacoma X-Runner V6 (4.0L , Manual Transmission). Upon entering my garage yesterday, I noticed that the driver side headlight of my truck appeared opaque (I believe this is referred to as a foggy headlight). I'd like to restore the assembly to its original beauty. Is there a way I can do that myself or do I have to purchase a new one? I'm assuming I have to buy a new one but still, I'm not jumping to conclusions. In case I have to simply purchase a new one, I've already done some browsing around online for vendors, and I have narrowed it down to two possible vendors.. Before I make the purchase I just want to know which would be a better deal.. I've heard of both but have never dealt with either..
    http://www.autolightcenter.com/toyota/tacoma/headlights.html#MTQ1Njk
    or
    http://www.rockauto.com/catalog/raf...og=41&partnum=20657800&a=FR41-20657800-333542
    Forgive my long post. Thanks in advance.
  2. Nov 22, 2010 at 4:36 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    Honestly, I'd stay away from either of those headlights and go to the dealer for a new one. Aftermarket headlights have been known to have a lot of fogging issues. There is a "Buy/Sell/Trade" section on this forum, you might find someone selling just what you need. You also can take your light apart to let it dry out and re-seal it. Welcome to TW, and good luck with the headlight.
  3. Nov 22, 2010 at 4:36 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    preheat your oven, turn the oven off, stick the headlight in there for 8-10min, take out, pry apart, clean the inside/outside, then re-seal with quality sealant
  4. Nov 22, 2010 at 4:38 PM
    08chocotaco
    08chocotaco Well-Known Member
    TAYLOR
    San Diego/Los Angeles
    2016 Silver TRD Sport
    No current modifications
    cant help you with out a picture. you honestly might just have to buff it out and itll come right out but if i cant see, then i wont be able to help you
  5. Nov 22, 2010 at 4:39 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
  6. Nov 22, 2010 at 6:38 PM
    05 X-Runner
    05 X-Runner Murdered X
    Brett
    Napa, Nor-Cal. Whine Country U.S.A
    BSP 05 X-Runner, 07 TRD Sport Super White
    HVM C/F X-Runner badge 1 of 6 made,P/C'ed black rims,Blacked out Billet Grill,BLHM,HID's,Tinted tail covers, Fog light mod,BFLM,C2C Black eyelids,,C2C 1.75" Front drop 2" rear,C2C Hoodstruts,URD Shortshifter,URD T-CAI.Custom Coupe shiftball, NST Manifold Spacer.. 07 TRD Sport Super White,De-badged,White headlight Mod,Fog light mod,White tail light mod,C2C white eyelids, C2C hood struts
    ^^^ What he said, that is the best way to do it, like others said try to stay away from aftermarket headlights they tend to leak and fog up..
    Oh welcome to TW and congrats on the X-Runner
  7. Nov 22, 2010 at 6:41 PM
    Leadgolem
    Leadgolem Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
  8. Nov 22, 2010 at 6:50 PM
    05 X-Runner
    Brett
  9. Nov 22, 2010 at 8:44 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Wait, what is the problem here? Is there moisture in the headlight or is it fogging due to the sun/dirt?
  10. Nov 22, 2010 at 8:51 PM
    08chocotaco
    TAYLOR
    exactlyyyyy
  11. Nov 23, 2010 at 8:55 AM
    Emanon
    Emanon Well-Known Member
    AZ
    05 BSP Xrunner
    AFe II, URD SS & trac bar, Sittin Sic Coils, Sways & Monos, QA1s, Dynomax VT, CC Stg III & LW Steel Flywheel, TRD BBK
    Recently both my headlights started fogging up. I removed the headlight assemblys took the bulbs and let 'em sit in the sun for a few hours. At the same time I took a heavy grade silicone and covered the seams.
    Solved the issue for me.
    Would be a great time to pick up a 3M headlight restoration kit if the plastic is in rough shape.
  12. Nov 23, 2010 at 10:01 AM
    MacyHastings
    Macy
    California
    06 X-Runner V6
    I'm not 100 percents sure, but I believe the fogging is due to moisture..
    Thanks everyone for the replies! I'll follow your advice and take a gander at the buy/sell/trade section
  13. Nov 23, 2010 at 10:44 AM
    Emanon
    AZ
    05 BSP Xrunner
    I bet it is. Mine would fog up for days after I washed the truck. The seams had a few coats of clear silicone from where the assembly was pulled apart to do the black headlight mod. A new coat of silicone and 3 washes later no more fogging up.
    Tho I will prolly hit up eBay for a new set in the near future since the peeling clear coat they sprayed on the lenses is not looking so hot.
