Headlight Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cgs2k2, Aug 4, 2010.
  1. Aug 4, 2010 at 2:02 PM
    cgs2k2
    cgs2k2 [OP] Ohio Member
    Nadeem
    2006 AC 4x4 OR
    My damn headlights have had this problem before, but only one other time.
    My headlights will not come on, and neither will my highs!
    When I turn my lights on, my fogs come on but nothing else. Turn signals work, and again the fogs work, but not the highs/lows.
    What could be the problem? Anyone else experience this??
  2. Aug 4, 2010 at 2:29 PM
    judge
    judge Member
    Arizona
    08 prerunner Trd of road
    Set up both 12v outlets in cab to be on constant, Added two 12v outlets in bed & connected them to the battery through a 10 amp fuse.Added DRLs Great option. Then changed the fog lights to come on at any time the key is on.Also added leds to the glove box and arm rest box. Installed leds in my doors to come on with the dome light & leds under dash to light floor.
    A bad ground, Two fuses bad, bad conn
  3. Aug 4, 2010 at 3:09 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    Please check the fuses, it is locate under the hook, all 4 - 10amps fuses...... check it.
  4. Aug 4, 2010 at 3:59 PM
    cgs2k2
    Nadeem
    2006 AC 4x4 OR
    Thanks guys. I've checked all the correct fuses. Still no luck. I'm gonna take it into the dealership tomorrow I think... gahhh
  5. Aug 4, 2010 at 8:16 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Do you hear a relay clicking when you turn on your lights? Its quite noticable. There's one for fogs and one for headlights I believe. Pull your fog relay and listen for the other one, it could point to the culprit.
  6. Aug 4, 2010 at 8:23 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    bulbs need to be replaced?
