Headlight help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ccal, May 27, 2017.
  1. May 27, 2017 at 2:10 PM
    ccal
    ccal [OP] Well-Known Member
    carmen
    kirtland ohio
    2014 tacoma trd
    2.25 leveling kit
    Anyone know if just the headlight lens can be replaced or do I need to buy the whole assembly?? I hit a freaking seagull at 65 mph and it cracked my passenger side lens wtf
    timbobzimbob and ChadsPride like this.
  2. May 27, 2017 at 2:27 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    Dang it man, I've got no idea. But that's a bummer for sure.
    timbobzimbob and ccal[OP] like this.
  3. May 27, 2017 at 2:35 PM
    Pigpen
    Dan
    Northwest Montana
    Whole assembly. You can't buy just the lens. $225
    Blockhead and ChadsPride like this.
  4. May 27, 2017 at 2:38 PM
    FawkQ
    FawkQ Well-Known Member
    Alberta, Canada
    2013 TRD Sport DCSB V6 4.0 6M "The Sequel"
    Whole assembly.
    The lense is sealed to the housing.
    Search TW for a BHLM writeup and you'll see how it's sealed and the mess of sealant while taking one apart.
    ChadsPride likes this.
  5. May 27, 2017 at 2:59 PM
    OKTACO
    OKTACO Well-Known Member
    Ty
    2005 SR5 Taco
    I bought some ebay specials so far so good, changing isn't terrible but have to partially remove the bumper
  6. May 27, 2017 at 3:03 PM
    Pigpen
    Dan
    Northwest Montana
    You will be getting a visit from the condensation fairy if you didn't thoroughly seal them.
  7. May 27, 2017 at 3:03 PM
    Pigpen
    Dan
    Northwest Montana
    OP, stick with OEM
    Blockhead, ChadsPride and ccal[OP] like this.
  8. May 27, 2017 at 3:07 PM
    OKTACO
    Ty
    2005 SR5 Taco
    Sealed them pretty well needed two hard to pass on 125 a pair
  9. May 27, 2017 at 3:08 PM
    Pigpen
    Dan
    Northwest Montana
    If you added sealant, you should be good.
  10. May 27, 2017 at 3:16 PM
    ccal
    carmen
    kirtland ohio
    2014 tacoma trd
    2.25 leveling kit
    Definitely
  11. May 27, 2017 at 6:02 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    F'in nerve of that bird !!! Wtf
    ccal[QUOTED][OP] and ChadsPride like this.
  12. May 27, 2017 at 8:29 PM
    58yeoman
    58yeoman Well-Known Member
    Phil
    2014 Pyrite Mica Tacoma
    A lot more expensive than the old sealed beams.
    tomwil and ChadsPride like this.
  13. May 28, 2017 at 4:57 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    You might have spent less money up front, but most of the inexpensive aftermarket headlight assemblies are pretty pathetic in several important areas. First, as you've already heard, they allow condensation to build up and eventually ruin the inside of the housing. Second, the light pattern that they project is generally inferior to OEM. Sure, they may look identical to your originals, but I think you're going to find out that they're not even close in performance or durability.
  14. May 28, 2017 at 5:08 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Like a few others said, stick with OEM. Better fit, better seal and light output.
  15. May 28, 2017 at 6:34 AM
    OKTACO
    Ty
    2005 SR5 Taco
    Yea I'm not arguing I know oem is better, hell I work at a Toyota dealership.
    Wasn't trying to sway people the other way but don't think they are a horrible option if your short on cash
  16. May 28, 2017 at 6:44 AM
    Blockhead
    Pittsburgh, Pa.
    You work at a Toyota dealership? No employee discount?
  17. May 28, 2017 at 6:52 AM
    OKTACO
    Ty
    2005 SR5 Taco
    Not as much as you would think. I'll get what my pricing would be Tuesday
  18. May 29, 2017 at 6:25 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  19. May 30, 2017 at 6:49 PM
    ccal
    carmen
    kirtland ohio
    2014 tacoma trd
    2.25 leveling kit
    One guy never got back to me,, oh well
