Headlight help.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Heavenswake, Oct 14, 2020.
  1. Oct 14, 2020 at 8:16 PM
    Heavenswake
    Heavenswake [OP] Member
    07 Taco and my driver side headlight is kinda pointing at the ground now. The reflective shield is loose causing it the bounce over bumps as well. I wanted to go the route of just getting some new lights, like the tacoma beast ones. But after reading 64 pages about it I decided against it. Ordered 2 different sets off Amazon (since I could return them easily) and they both were really bad. Decided to order a single headlight from my work since I work at an auto parts store and it was honestly probably the worst performing one...
    And that leads me to now, I honestly think I want to just bake open my OEM and try to fix it but have no idea what is wrong inside. I don't want to be stuck with a driver side headlight that is even worse than it is now. Anyone have any suggestions or guides to fixing a loose shield inside the headlight?
  2. Oct 14, 2020 at 8:21 PM
    ixnay
    ixnay Well-Known Member
    Mark
    Portland, Oregon
    For $103, get a single lamp from headlights america. I'm pleased with mine (I replaced both my headlights for $206)
    Bodyguard89 likes this.
  3. Oct 15, 2020 at 8:51 AM
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    How about a oem set from a junk yard ? Oem is pretty good quality. Try car-part for local junk yards.
  4. Oct 15, 2020 at 11:01 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    All the time spent ordering, returning trying again. Get a set of oem headlights assemblies. If you work the parts guy you can get them for about $250ea. And be done with it imo.
  5. Oct 15, 2020 at 11:09 AM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Oem are 250 each?
  6. Oct 15, 2020 at 1:04 PM
    gotoman1969
    They normally retail for 300 but I assure if you talk to your parts guy you can get 15-20 percent off and get them for 250-260
  7. Oct 15, 2020 at 2:15 PM
    Heavenswake
    I'm gonna try to fix it and maybe go that route if I can't. Right now I seem to have it wedged back into position, but who knows if it will stay. Might bake it apart if I can't get it to stay there. I just can't believe how bad the oem replicas were.
  8. Oct 15, 2020 at 9:07 PM
    Muddinfun
    Muddinfun Well-Known Member
  9. Oct 15, 2020 at 9:14 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yep, very common. Look similar but do not perform the same at all. Example here. OEM is definitely the only way to go for replacement headlights.
    Hardscrabble and Island Cruiser like this.
  10. Oct 16, 2020 at 6:15 AM
    $yoda$
    Tom
    2007 Tacoma 4.0
    That’s a little pricey but I would still go that route. The original lights in my 07 are still perfect no moisture or any other problems. Cant go wrong with oem learned that one the hard way.
