Headlight HID
Discussion in 'Lighting' started by MedlinAround, Jan 27, 2011.
  1. Jan 27, 2011 at 11:13 AM
    MedlinAround
    MedlinAround [OP] Failure is the result of letting setbacks stop you
    Cody
    Richmond, Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's (.85), Eibach Coils, AAL, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, 4% Tinted Windows, Weathertec Floor Liners, Double Din Pioneer Player, 2 10" Memphis SR Subs, Plasti Blacked out Bumper, Grill, & Emblems, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Storage - Rotopax, Pelican 1600 waterproof case, Plano 42"case.
    When it starts to warm up a little, i am planning on doing the black headlight mod and replacing the grille. While i have the lights off i wanted to put of set of nice HID's in while everything is apart. Not sure on some nice HID's but i would something bright and looks good. Any opinions?
  2. Jan 27, 2011 at 11:21 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Visit the retrofit source (theretrofitsource.com). They have complete set-ups to convert your stock headlights to HID projector style headlights. If you just want a plug and play HID kit, you do not need to rip apart your headlights for this, just replace the stock bulbs with the HID's. I think there's a group buy for plug and play HID's going on now, if not, there will be another one shortly I'm sure.
  3. Jan 27, 2011 at 11:30 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    DDMTuning.com.
    Also, there's a member on here who sells good quality stuff. His user name is slimcubby
    EDIT: Are you talking about HID's, or projectors? Two different things.
  4. Jan 27, 2011 at 12:00 PM
    MedlinAround
    Cody
    Richmond, Kentucky
    HID's..
    Which are brighter?
  5. Jan 27, 2011 at 12:02 PM
    KPT
    09 Prerunner
    HID's are the bulb itself.
    Projectors are the lens.
    Do you want HID's, projectors, or both?
  6. Jan 27, 2011 at 12:04 PM
    MedlinAround
    Cody
    Richmond, Kentucky
    HID
    what about 10000k?
  7. Jan 27, 2011 at 12:05 PM
    KPT
    09 Prerunner
    Okay well then you don't need top pull your headlights apart. Just buy new bulbs and call it a day.
    The light pattern won't be nearly as good without projector lenses, but plenty run them without, myself included. Just make sure you aim them properly so you don't blind anyone.
  8. Jan 27, 2011 at 12:08 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    just HIDs are going to blind the hell out of everyone on the road unless you aim your headlights way down
  9. Jan 27, 2011 at 12:08 PM
    MedlinAround
    Cody
    Richmond, Kentucky
    Yeah, which ones do you run? I know i don't have to pull them apart, but while i had everything off doing the black headlight mod i was going to install them.
  10. Jan 27, 2011 at 12:14 PM
    KPT
    09 Prerunner
    That's correct. I found a good middle ground though where they still give me plenty of road visibility, and I don't get flashed by any oncoming drivers.
    Also helps to have 35W's instead of 55W.
    I run DDM 6000K hids. Anything above that would be too blue for my taste. I acutally wish I got 5000k's.
  11. Jan 27, 2011 at 12:14 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2. I had a HID kit with my stock housings and the output was okay but not nearly as good as my new retros!!:D
  12. Jan 27, 2011 at 12:23 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Is a retro kit easy to do?
  13. Jan 27, 2011 at 12:24 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    the morimoto mini d2 is easy, the fx-r and others are hard
  14. Jan 27, 2011 at 12:36 PM
    Pugga
    Massachusetts
    F-150 Mod
    I don't mean to thread jack, but how come the morimoto is easier, do you not need to open the headlight to install them? I spent a lot of time reading through TRS's website cause I'm getting close to doing a retrofit on mine.
  15. Jan 27, 2011 at 12:38 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    I have the FX-R's but I had mine made by Tim. I heard the mini's you dont have to do any cutting.
  16. Jan 27, 2011 at 1:13 PM
    PLC721
    Patrick
    Chandler, Az
    correct, tim had to cut a liitle bit on yours because the projector is bigger, it morimoto snaps right in.
  17. Jan 27, 2011 at 5:19 PM
    Pugga
    Massachusetts
    F-150 Mod
    Good to know, thanks guys!
  18. Jan 27, 2011 at 7:48 PM
    DevL
    DevL Well-Known Member
    I think that is about stupid. Brightest is at 4300-4500K. As you go up or down from there output goes down. You want dim purple headlights? Get 10,000K bulbs.
    Also using your stock reflectors and new Xenon bulbs is illegal, not to mention rude.
  19. Jan 27, 2011 at 10:56 PM
    PLC721
    Patrick
    Chandler, Az
    55 watt 6k will be about as bright as 35 watt 4.5k
