Headlight leaking
Discussion in 'Lighting' started by Blacknightowl11, Feb 3, 2023.
  1. Feb 3, 2023 at 8:00 PM
    Blacknightowl11
    Blacknightowl11 [OP] New Member
    Beth
    Poulsbo , Washington
    2018 Black Toyota Tacoma
    I need some advice my headlight has moisture inside it’s leaking somewhere and I don’t know where ? is there anything I can do ? Other than buying a new headlight?
    2018 Toyota Tacoma.
    Robnik and HondaGM like this.
  2. Feb 3, 2023 at 8:04 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW Beth….you made sure all the bulbs are installed correctly?
    Blacknightowl11[OP] and Robnik like this.
  3. Feb 3, 2023 at 8:11 PM
    Blacknightowl11
    Beth
    Yes
  4. Feb 3, 2023 at 8:22 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Well… unfortunately if you can’t locate where it’s not sealed your gonna have to replace it..
  5. Feb 3, 2023 at 8:27 PM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Hi Beth, welcome to TacoWorld!!
    Try throwing some flour on it, should be obvious where it's leaking.
    Wish you luck :)
  6. Feb 3, 2023 at 8:28 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    out of warranty?
  7. Feb 3, 2023 at 8:38 PM
    Blacknightowl11
    Beth
    Yea out of warranty , I was wondering if anyone else has had the same issue? I did look on YouTube and one video shows you how to take the lense off and reseal with a silicone sealant. sounds like a lot work. ‍♀️I’m not a mechanic.
    HondaGM likes this.
  8. Feb 3, 2023 at 8:42 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    May want to check the vents …I believe there 2 on yours
  9. Feb 3, 2023 at 8:42 PM
    Blacknightowl11
    Beth
    Okay thanks I’ll check it out.
    HondaGM likes this.
  10. Feb 4, 2023 at 6:32 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Good luck…and let us know what you find out:popcorn:
    wilcam47 likes this.
  11. Feb 4, 2023 at 4:42 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    First, welcome to TW! As to your questions, are the headlights original? Has the one that's leaking ever been replaced? Has it ever been hit, maybe in a parking lot? (Check the outside for scrapes.)
    Basically, if a headlight housing is leaking and already has water inside, replacement is the only real fix. Then you're going to end up asking question(s) about where to buy a housing and if aftermarket is as good as OEM - which they are not. (They are cheaper though.) A good alternative is to check the Classifieds here for a set that somebody has taken out.
