HEADLIGHT LED'S
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YoungGunz23, Aug 12, 2011.
  1. Aug 12, 2011 at 11:55 AM
    YoungGunz23
    YoungGunz23 [OP] Well-Known Member
    Caleb
    Monroe Louisiana
    08 TRD Off Road
    3" fabtech lift 33" federals
    i am getting some white LED strips to put in my headlight across the bottom. does anybody know how i can wire them to where when i turn my lights of they go off?
  2. Aug 12, 2011 at 12:03 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    You could use the marker light wire as a "switch" so when they are turned on, they'll turn on a relay and in turn the LED's will come on. It'd require splicing into the wire but it'd work and the LED's would come on everytime you turn the parking lights on (and would also be on with headlights).
  3. Aug 12, 2011 at 12:13 PM
    TacomaPrime
    TacomaPrime Cybertronian Tacoma
    Greg
    Illinois
    05 Prerunner SR5 TRD off road
    Yeah. Just use some of those vampire clips. that way you dont have to actually cut the wire.
  4. Aug 12, 2011 at 12:15 PM
    YoungGunz23
    Caleb
    Monroe Louisiana
    08 TRD Off Road
    ok thanks. do u think i need to put a in line fuse on them so if the spark it dont burn my headlight out?
  5. Aug 12, 2011 at 12:25 PM
    Pugga
    Massachusetts
    F-150 Mod
    I would put an in-line fuse on the power wire, not necessary on the jumper wire from the marker light though.
  6. Aug 12, 2011 at 12:50 PM
    YoungGunz23
    Caleb
    Monroe Louisiana
    08 TRD Off Road
    ok man thanks
  7. Aug 12, 2011 at 1:42 PM
    fvtalon
    fvtalon Well-Known Member
    Southern BC
    07 DC TRD/Yamaha
    285/65/18 BFG ATs on MKWs Leer Cap
    Tap the parking light circuit, it's already fused. I wouldn't use a vampire clip though. They can tend to cut the parent wire on installation and they don't seal up or anything which opens the door to corrosion. I would carefully strip a 1/2" portion of insulation on the parking light wire, then wrap and solder your wire onto it. Then finish with tightly would electrical tape.
  8. Aug 12, 2011 at 1:48 PM
    Pugga
    Massachusetts
    F-150 Mod
    I'd heat shrink in stead of electrical tape. Better seal. You're probably right about just tapping in though, I doubt those LED's have much draw to where they'd require they own ciruit.
  9. Aug 12, 2011 at 1:49 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    would you even be able to get a piece of heat shrink on there without cutting the wire?
  10. Aug 12, 2011 at 1:52 PM
    Pugga
    Massachusetts
    F-150 Mod
    You'd have to slice the heat shrink (Sounds useless but it works!) It's a pain to get it to shrink the way you want it when it's sliced but it does work. I usually wrap it with electrical tape afterwards but the heat shrink first definitely helps keep the splice dry and protected.
  11. Aug 12, 2011 at 3:01 PM
    YoungGunz23
    Caleb
    Monroe Louisiana
    08 TRD Off Road
    ok guys thanks
  12. Sep 25, 2011 at 7:14 PM
    2chains
    2chains Well-Known Member
    Calgary, Alberta
    2010 Tacoma DC LB 3" Revtek lift
    3" Revtek lift, k&n 63-9025 intake, tailgate debadge, OEM Bed mat, decals gone. helo black max 6 bs 4.5 os-12,duratrac 285 70 17,smittybilt light bar, kc slimlites, pioneer pb3300 bt, window tint, weathertech digfits, raider lorider elite tonneau, at2525xl,
    Any updates on this? Curious to see how these turned out...
  13. Sep 25, 2011 at 7:43 PM
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails WANT: Rear Plate Bumper, RokBlokz mud flaps, Steel bed cage
    +1
    I usually run with headlights on day or night to improve my visibility to others, but a string of bright LED's as running lights (similar what Audi and other euro companies are now doing) could be a possible alternative. I'd like to know how this turns out.
  14. Sep 26, 2011 at 2:52 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    I just tapped into the headlight wire
  15. Sep 28, 2011 at 6:41 PM
    2chains
    Calgary, Alberta
    Have you got any more pics of the lights, where did you get the LED's?
  16. Sep 28, 2011 at 6:46 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Bull bar, nerf bars, bed extender, tonneu cover, bug deflector, wish list,....
    I bought string LED's at Advance Auto Parts. I have not installed them yet, but it looks like it would be easy to just wire them up by tapping into the marker light or headlight wires. They come with 3M tape so they just stick on.
  17. Sep 28, 2011 at 11:23 PM
    sytfu510
    sytfu510 INSTAGRAM: sytfu510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit DMZ LT Kit TRD Supercharger SCS Wheels BAMF
    think I know what you're talking about, I used the same to mount in my bed, they're pretty dam bright and mount easily.
  18. Sep 29, 2011 at 6:42 PM
    2chains
    Calgary, Alberta
    thanks for the lead...looking forward to getting some!
