Headlight lens?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yotacoma92, Apr 16, 2012.
  1. Apr 16, 2012 at 12:46 AM
    Yotacoma92
    Yotacoma92 [OP] TacoLover
    Zack
    lima, ohio
    99 Tacoma SR5 4x4
    Westin brush guard, smitty built nerf bars, roll bar, K&N air filter, Helo 17" Rims with 285-65-17 BFG KM2's, OME 2in lift springs, 0-2.5 lift Bilstein 5100 struts, OME 3in lift leaf springs, 5125 bilstein rear shocks, Projector HID headlights, Blacked corner lamps.
    Does anyone know how to remove the plastic cover off of the headlight assembly? mine are yellowed so im goin to try and clean them.
  2. Apr 16, 2012 at 1:01 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Search BHLM...(black headlight mod)!
    You have to remove a few screws, remove all rubber pieces and then bake them in an oven that's preheated at 300 for 7 minutes! The glue will soften and then you can pull them apart!
  3. Apr 16, 2012 at 1:03 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Just get a orbital buffer and some rain-x yellow headlight removal stuff and got nuts lol...much easier
  4. Apr 16, 2012 at 1:03 AM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    The yellow is on the front of the lns most likely, just get a headlight restoration kit available to you via your nearest auto parts store :D
  5. Apr 16, 2012 at 6:07 AM
    JdevTac
    JdevTac Bawnjourno
    Josh
    GA
    2013 DC TRD-OR 4x4 Pyrite Mica
    What everyone else said with the restoration. I just got the Turtle Wax kit and it worked just fine. I only ended up having to use a little of the provided lens compound, and rubbed it in real good then buffed it out, and applied the sealant wipe or whatever it is and my headlights looked 90% better! They weren't crystal clear but what can I say about the shitty plastic material they used.
    On a side note I haven't seen any 1st gens do the BHLM. I think it was because of the headlight design being absolutely different from second gens, in that majority of the space inside the 1st gen light is a designated reflector whereas there is a lot of useless plastic surface in 2nd gens that can be blacked out. Someone correct me if I am wrong.
  6. Apr 16, 2012 at 6:29 AM
    puckstopper55
    puckstopper55 Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    My first gen ('95.5) had a 1 piece head light .. not just the bulb, but the entire light had to be replaced. I would imagine that is why you haven't seen any 1st gen BLHM
  7. Apr 16, 2012 at 6:38 AM
    k9cop
    k9cop if your not the lead dog, the view never changes
    Farva
    Hogwarts
    10 tacoma dbl cab trd off road prerunner
    CST 3.5" spindles, King 2.5 rr ,All Pro Expo's, Ext. Billy 5100's rear, Ext rear All Pro brake lines, LR UCA's, debadged, Cobra 29,2ft firestick, satoshi by jim, ARB front bumper, Smittybuilt xrc8 winch, wethatecs, bhlm also by jimbob, belgium malinois and German Shepherd in bed
    i used cutter bug spray w/ the pump and an orbital. depending on how bad it is it will make them look new again.
  8. Apr 16, 2012 at 3:26 PM
    Yotacoma92
    Zack
    lima, ohio
    99 Tacoma SR5 4x4
    the oxidation is on the inside of the lens, ive cleaned the outside with the restoration kit. it helped alittle bit but not enough
  9. Apr 16, 2012 at 3:28 PM
    saundern
    saundern Swerve for nothing
    Nick
    Greenville, SC
    2005 TRD Sport
    time to buy some new ones
  10. Apr 16, 2012 at 3:30 PM
    boshak
    boshak Well-Known Member
    Tony
    Southern California
    2003 Manual 4x4 5VZ-FE
    OME 881's, Wheeler's 5-leaf pack, Bilstein 5100's
    Are you 100% sure its inside?
    I thought the same but tried the HF kit twice. The second time I used a cord drill that spins way faster than my cordless. I even talked to the owner of the kit... he told me to try again and be heavy and patient on the sanding and polishing. Lights look brand new now.
  11. Apr 16, 2012 at 6:14 PM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    if it's that bad just buy new headlight assemblies and save yourself the hassle
  12. Apr 16, 2012 at 6:24 PM
    Yotacoma92
    Zack
    lima, ohio
    99 Tacoma SR5 4x4
    If i had the cash id get some black projector lights but thats expensive and my budget sucks
  13. Apr 16, 2012 at 6:27 PM
    Yotacoma92
    Zack
    lima, ohio
    99 Tacoma SR5 4x4
    like these
  14. Apr 16, 2012 at 6:36 PM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    I'll be doing a 1st gen HID BHLM this week. I'll satin black the reflector area and keep the shrouds "chrome". I've seen a few on here. Will post some picts when done.
  15. Apr 16, 2012 at 8:15 PM
    Yotacoma92
    Zack
    lima, ohio
    99 Tacoma SR5 4x4
    thanks ill wait for pics
