headlight moisture
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bluebeast, Jul 6, 2010.
  1. Jul 6, 2010 at 3:49 PM
    bluebeast
    bluebeast [OP] Active Member
    06 bluebeast
    smitty bulls bar procomp 3in lift westin nerf bars
    i bought a pair of black out headlight, and now it has moisture inside. how do i get that moisture out and from not coming back. i know some say to open it up and clean it but im trying to stay away from that. any info will help
  2. Jul 6, 2010 at 3:52 PM
    Chad
    Chad Well-Known Member
    Chad
    Raleigh, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- BHLM -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- 09+ Access Cab Rear Headrest Removal
    I'm assuming you bought these off eBay? That's your mistake, but we've all had them. Your only options are to break it open clean it out and re-seal with some quality sealant or contact the eBay seller and say their product did not work properly and leaks.
  3. Jul 6, 2010 at 3:55 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Uninstall the headlights and have them sit in your house till they clear up. Once clear, grab some RTV and reseal the out sides of them. (I used grey permatex). Besure to get it in all the places where it looks like water could get in.
    I resealed mine before I installed them and no problems so far. GL
  4. Jul 6, 2010 at 3:57 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I wanted until mine dried out and just resealed it on the drivers side. The passenger side hasnt had any issues yet (knock on wood).
  5. Jul 6, 2010 at 3:59 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    All the aftermarket ones need to be sealed it seams!
  6. Jul 6, 2010 at 5:36 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Tip: To dry them out quicker, you can use silica gel packets....
  7. Jul 6, 2010 at 5:57 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    Anyone ever try sticking a vacuum hose through the opening for the bulb?
  8. Jul 7, 2010 at 7:48 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I just put them in the dryer for 10 minutes on fluff....
    :D
    ...and back to reality,,, if you're in a hurry use a hair dryer on a low setting. Note that this drying process may not remove all of the fog "residue" on the inside. Even with drying and sealing, you _may_ still have to open 'em up to clean it off the lens.
  9. Jul 7, 2010 at 8:02 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2.
    Tie a couple to a string, and insert thru the hole the bulb mounts into. Leave it for a couple hours, seal the lens good, and remove the packets. Then, Remount bulb.
  10. Jul 7, 2010 at 8:19 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    x2...I had this problem in an old car. I used a hair drier to dry it out, then I drilled a small drain hole in the bottom (where the state inspector wouldn't notice), but I'd recommend you reseal them properly with some silicone sealant or something. Something should be done though because it greatly reduces the headlight's effectiveness, and you could fail inspection if you're in a state the requires it.
  11. Jul 7, 2010 at 5:51 PM
    bluebeast
    06 bluebeast
    thanks guys
  12. Nov 2, 2010 at 7:26 PM
    billas333
    billas333 They Still Love To Hate Me! - T.O.
    Joel
    NorCal
    2008 4x4 Tacoma Sport
    Mods so far: Tube steps from toyota, Bed extender from toyota, Spare Tire lock, Sound System Makeover, Tacoma All-Weather heavy duty rubber floor mats. Rear TSB, Icon Coilovers w/ TC UCA's and 3inch rear block with rear 5100 bilstein shocks, Black Headlights, Grillcraft black grill, Devil Horns from Andres, Black Headlights, Chrome Liquid Metal Gatlins Wheels, 285/70R17 Nitto Tera Grapplers, Wet Okole Seat Covers! Seat Belt Chime Mod, Flowmaster 50 series dual exhaust, Debadged tailgate, TRD Decals, HID hi/low + fogs.
    Yea this is a b@$%$! My passenger headlight had moisture in it so I got rid of it with a silica pack, but when I washed it again it got moisture in there, so obviously it has a leak.
    Now my driver light is doing it too.
    I am driving around witha truck that looks like it is crying this sucks!
