Headlight not coming on
Discussion in 'Lighting' started by tealduk, Jan 19, 2009.
  1. Jan 19, 2009 at 6:55 AM
    tealduk
    tealduk [OP] New Member
    Oklahoma
    1995 tacoma 4x4 w/six"lift
    3" body lift, 3"susp. lift
    My lights do not come on when I turn the light switch on unless I pull back on the trun signal switch. When I pull on the switch, the brights come on but the dims never come on no matter what. If I hold the swtich back I can drive with my brights on but oncoming traffic doesn't appreciate it.
    I have already changed the trun signal swtich and wiring harness. It hasn't helped. Before I take it to a mechanic for 65-85 bucks an hour I would like to see if you guys have any advice.
    Kev
  2. Jan 19, 2009 at 7:45 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Did you change the bulbs?
    Check the wiring at the lights also. Could be a bad ground somewhere....
  3. Jan 19, 2009 at 8:10 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    I hope so...
    Wife's cousin had this happen to him a while back -- he had a loose wire in the steering column.
    and welcome to TW :wave:
