Headlight not working.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gabassman, Aug 20, 2013.
  1. Aug 20, 2013 at 6:41 PM
    Gabassman
    Gabassman [OP] Drive it like a 4WD
    Tyler
    Georgia
    I noticed this problem a week or so ago. My passenger head light went out(low beam). I figured bad bulb but before I bought a new bulb I swapped bulbs and both sides started working. I drove around and the passenger bulb went out again. I pull the plug and the light and re install it and it will work again and of course ill drive a little bit and it will go out. The high beams will work all the time.
    I took the back off the plug and cleaned out some of the dielectric grease, it looked really gunked up and black. started working but went out again.
    This is starting to become really aggravating and i hate something not work correctly.
    Any suggestions would be awesome.
  2. Aug 20, 2013 at 8:37 PM
    Gabassman
    Tyler
    Georgia
    No one really? Well anyhow goodnight bump
  3. Aug 20, 2013 at 8:46 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Wiggle the wires on the connector. Does it flicker? Found your problem. Pinpoint the problem first. Then replace that part. Headlights are a pretty simple circuit.
    If its the pins in the headlight connector, you could probably get a new pigtail.
  4. Aug 20, 2013 at 9:29 PM
    Gabassman
    Tyler
    Georgia
    Yea I've wiggled them no flickering. It only works after I remove the connecter and plug it back in. Then after riding a bit it will go out again.
  5. Aug 21, 2013 at 7:52 AM
    Gabassman
    Tyler
    Georgia
    Goidmorning bump
  6. Aug 21, 2013 at 7:55 AM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    when it goes out do you still have power and ground at the plug
  7. Aug 21, 2013 at 9:33 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    You need to check to see if you have power at the plugs with a volt meter. Bulbs can intermittently work sometimes, even if the filaments are broke. If each end of the filament make contact they can hold and light up. I've had this happen quite a few times. Then they will turn off if the filaments seperate.
  8. Aug 21, 2013 at 9:35 AM
    adriancast
    adriancast Well-Known Member
    Adrian
    Ontario, Ca
    2005 Tacoma 4x4 TRD Off-Road
    -2.5 Donahoe Coilovers -All Pro Standard Leaf Pack -All Pro U Bolt Flip Kit -Front/RearWheeler Super Bumps -Extended rear Bilstein 5100s -Flowmaster 40 Series -All Pro IFS Skid -All Pro Transmission Skid -Bruteforce Hybrid Bumper -30" Double Row LED bar -400 Watt Anytime -TRD Seat Covers -ABS Kill Switch -Locking Center Console Mod -Rear Differential Breather -BHLM -Anytime Fog Light Mod -Toyota Hilux Snorkel
    Push in all the wires. Probably loose.
  9. Aug 21, 2013 at 1:26 PM
    Gabassman
    Tyler
    Georgia
    Pulled the bulb out and now the filament is broke. So I put in my spare bulb still not working. Now I'm gonna try with the drivers bulb to see what happens.
  10. Aug 21, 2013 at 2:16 PM
    Gabassman
    Tyler
    Georgia
    Used a volt meter. Low beams on there is not any voltage showing. High beams I'm getting 11. Whatever. Must be a loose connection.
  11. Aug 22, 2013 at 4:43 PM
    Gabassman
    Tyler
    Georgia
    Got it working it was the fuse for the passenger low beam. Didn't know there were 4 fuses fur the headlights
  12. Oct 21, 2013 at 2:12 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    I know this a bit old, but any issues since replacing the fuse. Mine are doing the same, i haven't replaced the fuse yet, it is just strange that it would ever work if the fuse is out... right?
  13. Oct 21, 2013 at 8:14 PM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    That's my thought, fuse would be all or nothing.
    Either way, checked mine and they're fine, so my problem is likely the harness.
  14. Oct 21, 2013 at 10:39 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    All the wiggling and the light going off and on will also blow a fuse. The lamp was probably flickering due to a loose connection when driving down the road also.
