Headlight plastic welding
Discussion in '2nd Gen. Tacomas (2005-2015)' started by apotter, Nov 11, 2011.
  1. Nov 11, 2011 at 5:38 PM
    apotter
    apotter [OP] Well-Known Member
    Southern Maine
    2023 Tacoma
    Does anyone know the type of plastic they use on the Tacoma headlight housing? I brought one of my project lights to a plastic supplier to have a tab repaired today and I was asked what type of plastic it was......right. I was told either A.) Call the manufacturer to see if it's pastic weldable, or B.) he'll figure it out for $65. A.) yeah right B.) F that.
    Has anyone out there plastic welded the headlight housing?
  2. Nov 11, 2011 at 6:40 PM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    Sorry I can't tell you about the kind of plastic, but I can tell you how I would first try to repair almost any plastic on my truck... J.B. Weld is the most amazing stuff I've used. You can mould it, build it up in stages, and even drill and tap it with threads.
  3. Nov 11, 2011 at 6:44 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    JB weld x2
  4. Nov 11, 2011 at 7:09 PM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    None yet! It's new!
    An alternative to J.B. Weld is called Marine-Tex. You can get it at any boat supply place and some home improvement places. I think it actually works even better than J.B., but it's harder to find. The cool thing about it is, if you're in a hurry, you can cure it in 15 minutes with an I.R. heat lamp. :)
    I used to use it on a chronically breaking intake air box in a Porsche 911. Early Bosch Motronic injection systems would occasionally backfire through the intake and break the box. I kept Marine-Tex on hand to repair it. It saved me hundreds of dollars on numerous occasions. Curing in 15 minutes is a really cool option.
  5. Nov 15, 2011 at 6:59 PM
    apotter
    Southern Maine
    2023 Tacoma
    Thanks for the alt. fix. I'm sure it would work alright, but I'm really curious if these things are even plastic weldable. Anyone have any idea what type of plastic these things are made of? or of a place I could contact to find out? There must be somone on this site that does plastic welding and has tried repairing a headlight.
  6. Nov 15, 2011 at 7:02 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    rough up the area and use a 2 part plastic epoxy
  7. Nov 15, 2011 at 10:02 PM
    squamish VFR
    squamish VFR Well-Known Member
    Squamish B.C. Canada
    '06 tacoma 4door shortbox
    Bilsteins set at 2.5" OME Dakar rear leaf packs, FJ manual TC conversion, basket winch front and rear, hidden hitch in the front behind licence plate. Spyder headlights, tailgate seals.
    It will have a two letter code like PC or PE. Might be ABS. Any epoxy should work with some mesh drywall tape for strength. definite DIY.
  8. Nov 16, 2011 at 7:36 PM
    apotter
    Southern Maine
    2023 Tacoma
    I see it now. Housing: PP-T20
    Thanks!
  9. Nov 16, 2011 at 7:39 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ... X 2 on the JB Weld
  10. Nov 17, 2011 at 6:35 AM
    Kurdain
    Kurdain Well-Known Member
    Portland, OR
    PP is PolyPro (Polypropylene).
    Quite easy to weld with the correct equipment.
    However for best results you would need the exact same plastic rod stock and even the color to get the strongest bond.
    PP comes in about any color and welding it in the past I have noticed slight differences in different colors of PP even though both pieces were the 'same' plastic.
    If anyone is curious you can not join different types of plastic together using traditional plastic welding. ANY contamination will severely weaken the bond as well, so you need to know what you are doing to get the best results.
    In any case you will want to use a quality plastic welding machine, preferably with the high speed tip and rod preheat channel. Done correctly the welds can end up stronger than the stock material.
    If you've never plastic welded before and don't have the correct equipment and rod, I suggest you just glue it.
  11. Nov 17, 2011 at 9:36 AM
    squamish VFR
    I don't think epoxies like jb weld or marine Tex will bond to polypropylene Google is your friend.
  12. Nov 17, 2011 at 10:15 PM
    apotter
    Southern Maine
    2023 Tacoma
    This all seems completely logical. thankfully I have a spare housing which has proven to be useful. while completely in agreement wth using the right tool for the job, in the case of plastic welding have you ever used a soldering iron for joining similar plastics together? Polypro seems to be a decent candidate for using a soldering iron to fix (second best to prof. plastic welding).
  13. Nov 18, 2011 at 6:14 AM
    Kurdain
    Portland, OR
    You can, I've done it with toy car and crap like that.
    The weld won't be very strong, it might hold up but it's hard to say.
    The soldering iron will burn the plastic too, which can contaminate if you try to weld it later.
    The plastic welders use super heated air to 'plastisize' the material, so it never touches the actual weld point (there are a some exceptions like guide channels, etc.).
    They make some crazy epoxy materials, still probably your best bet.
  14. Nov 18, 2011 at 6:30 AM
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    I welded two Optima batteries once... UPS cracked the case during shipping. Got a 2nd one and the same thing happened... They refunded my money and said to recycle them cause they cant ship them back. I welded both and they have been fine for the past 3 years(Just used a piece of the base and a soldiering iron). Cant complain for 2 free optima's.
  15. Nov 20, 2011 at 7:58 AM
    apotter
    Southern Maine
    2023 Tacoma
    Greatly appreciate the advice. Thankfully with the project I'm working on I have nothing to lose really so I attacked it with the iron to save some $$, and make it look decent (epoxies always tend to look botched to me). The piece is surprisingly strong (for now), although no doubt somewhat brittle. The PP-T20 appears is very weldable to anyone out there looking to fix/replace a tab. I can post pics of how the solder iron method works out if interested.
