headlight projector retrofit
Discussion in 'Lighting' started by 1320king, Dec 26, 2015.
  1. Dec 26, 2015 at 3:08 PM
    1320king
    1320king [OP] Well-Known Member
    roseville ca
    in search of Tacoma
    who sells the kit where you dont have to cut the housing to install the projectors?
  2. Dec 26, 2015 at 3:10 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
