Headlight Question
Discussion in 'Lighting' started by dwwest281, May 29, 2011.
  1. May 29, 2011 at 7:44 AM
    dwwest281
    dwwest281 [OP] New Member
    Galveston County Texas
    08 Prerunner
    I have a 2008 Tacoma. I have had to replace 3 passenger side headlights since I bought it new. The low beam is what burns out. Never a problem on the driver side. Any ideaas on the cause? Thanks in advance.
  2. May 29, 2011 at 1:35 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    Make sure that the headlight assembly is bolted down properly. Vibration could be your problem.
  3. May 29, 2011 at 1:49 PM
    joes06tacoma
    Joe
    Central Coast, CA
    X2
    Also make sure you can't see moisture inside the lens.
    When it's working, does that headlight seem to be burning dimmer than the other? Thinking maybe low voltage or bad ground.
  4. May 30, 2011 at 1:55 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    Also try to clean the contacts and apply some dielectric grease, a poor contact can cause them to go bad sooner. Also, be sure you aren't touching the glass on the bulb when you install them, the grease on your fingers is sufficient enough to reduce longevity.
