headlight removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wcm608, May 23, 2010.
  1. May 23, 2010 at 9:59 AM
    wcm608
    wcm608 [OP] Well-Known Member
    Pittsburgh, Pa
    08 DC LB 4x4 SR5 Impulse Red
    for all those who have removed their headlights for any reason I have a
    question. I have removed all 4 screws but cannot get the filler piece under
    the headlight to release from the fender side. Out of all the bhlm threads I
    have read, I have not seen this mentioned. What's the trick?
  2. May 23, 2010 at 10:01 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    what I did is, say you are doing the left side, I turned the steering wheel all the way to the left undid the rain/mud protection thing and reached up inside there to get the last bolt out.
  3. May 23, 2010 at 10:04 AM
    TheOtherGuy
    TheOtherGuy Well-Known Member
    Cajun Country
    05 Access 4x4
    It is only held in by a clip going to the front fender and I think one screw(but you have probably already removed the screw). All you need to do is grab it and pull it towards the center of the truck and it will just pop out.
  4. May 23, 2010 at 10:05 AM
    wcm608
    Pittsburgh, Pa
    The filler under the headlight is what i'm talking about. Do you just put your
    hand behind there and push forward?
  5. May 23, 2010 at 11:47 AM
    wcm608
    Pittsburgh, Pa
    Thanks!
    Got them out. One clip partially broke in the corner but still usable.
