headlight replacement 96 tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by bail_w, Feb 12, 2010.
  1. Feb 12, 2010 at 10:03 PM
    bail_w
    bail_w [OP] Member
  2. Feb 12, 2010 at 10:51 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    id be a whole lot cheaper and easier to just go to wall mart and buy one
    if your going stock anyways
  3. Feb 12, 2010 at 10:58 PM
    bail_w
    bail_w [OP] Member
    You sure walmart have it?
  4. Feb 12, 2010 at 11:04 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    if not autozone/advance auto/ o rileys will
  5. Feb 12, 2010 at 11:14 PM
    00taco
    00taco Well-Known Member
    Casey
    cali
    black 00 tacoma v6
    wheels, tires, sound system, hid headlights, 1st gen fog light mod, tinted tails hella 500s on custom light bar, dust light, led white guages/dash lights, color matched grille, exhuast, blacked bumper and accents....
    walmart will have the bulbs but not the actual light housing
  6. Feb 13, 2010 at 7:54 PM
    bail_w
    bail_w [OP] Member
    Wrong, They are a lot more expensive. ~60 dollars + tax
  7. Feb 14, 2010 at 5:44 AM
    Air_Ops
    Air_Ops Active Member
    Peter
    N.W. VT
    01 Ltd Dbl Cab
    TRD Headers, Cat Back Exhaust, Airaid Intake Tube, LC Engineering Throttle Body Gasket, Bilstein 5100 Series Shocks, Wheeler's Add-A-Leaf, LC Engineering Tundra Brake Kit, Re-Framed
    There are better choices for headlight upgrades. It will depend how deep your pockets are. Hella makes the H4 vision plus replacement lenses which will convert your headlights to a replacable H4 bulb like the newer tacomas. The advange is a better light pattern and the ability to replace just the bulb not the whole sealed beam assembly.
    http://www.rallylights.com/Hella_200mm_H4_Headlamps.aspx
    according to the sylvania chart they list H6054 for your truck
    http://www.rallylights.com/detail.aspx?ID=139
    These lights are more expensive than a sealed beam bulb from a auto parts store, but how much is being able to see worth.
