HeadLight Restore
Discussion in '2nd Gen. Tacomas (2005-2015)' started by baldy54, Feb 14, 2012.
  1. Feb 14, 2012 at 8:16 AM
    baldy54
    baldy54 [OP] Well-Known Member
    Orlando, FL
    06 Prerunner SR5
    I know this has been answered. I have look but could not find anything. I have a 06 dbl cab. And the headlightss are starting to get a haze on them. How do I make them like new again?? And what things do I need to use to make them look new again.
  2. Feb 14, 2012 at 8:30 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Look for 3M's Headlight Restoration kit.
    DrFunker likes this.
  3. Feb 14, 2012 at 8:32 AM
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    That stuff did almost nothing for my GF's old Civic. Some folks swear by it though...good luck.
  4. Feb 14, 2012 at 8:33 AM
    CBrva
    CBrva Well-Known Member
    Glen Allen, VA
    2012 Sport DCLB 4x4
    Toytec Boss, LR UCAs, Dakars, FN f(x)pro wheels, ko2
  5. Feb 14, 2012 at 8:35 AM
    sfoxwoody
    sfoxwoody Well-Known Member
    Calhoun, Ga
    05 TRD Sport, 4x4, BSP, LB
    none yet
    X2 on 3M
  6. Feb 14, 2012 at 8:36 AM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
  7. Feb 14, 2012 at 8:49 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Saw an eval in Consumer Reports that listed the Syvania and 3M kits as the best. Most interesting part though was that even the best kits above showed degradation of the outer treatment after only 3 months.
  8. Feb 14, 2012 at 9:18 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    ill suggest that after you polish them nice and clear to use a product called penetrol. its a paint additive you can get from home depot for about 9 bucks. if you do it right it will last about a year in most cases.
    to do it right start with clean clear lenses. using a foam paintbrush that isnt soaked to heavily apply to headlights. you have to do this when its warm enough outside so it has at least one solid warm day to dry. if you drip it on your paint wipe it off right away. this stuff also brings back faded plastic trim that has weathered. sometimes 2 coats are needed for trim. same deal let it dry. ymmv cheaper than new lights or trim. this stuff was widely used on the jeep boards with good success
  9. Feb 14, 2012 at 9:20 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    I like the new mothers kit specifically for headlights.....works great. And lasts a good while as well.
  10. Feb 14, 2012 at 10:05 AM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Same problem here. Got headlights cleaned up ,but as stated above only seems to last 3 months. Am going to try the above suggestion of a product called Penetrol from home Depot. Will wait until summer to give it a try. Thanks for the info.
  11. Feb 14, 2012 at 10:41 AM
    24medic
    24medic Member
    Kevin
    Nor cal
    05 Tacoma black 2.5 coil overs mb choas
    adjustable coil overs, mb choas, 265/74 16 wranglers intake, mag light ,
    No matter which product you use just keep repeating till lense is clear and u have to use a sealant after or it will fog quickly
  12. Feb 26, 2012 at 8:04 PM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    Looking at a kit to fix the lights on my Sequoia.
    I tried the 3M kit. It did not work very well. I will say the lights are no longer faded, now they are all cloudy. I am going to try another kit and then might consider replacing the lights.
  13. Feb 26, 2012 at 8:12 PM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    I've heard about lots of restoration kits, but everyone says that they help a little at first but the haze comes back fast.
  14. Feb 27, 2012 at 6:01 AM
    hotrod45
    hotrod45 Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    what is the name of the sealant you are using and where did you get it? i've done several lights and they come back quickly in fla. maybe the sealant is the missing ingredient.
  15. Feb 27, 2012 at 6:09 AM
    disk_55FL
    disk_55FL Well-Known Member
    disk
    Buckeye
    '17 TRD Sport MT
    Autogeeks.net had a discussion about headlight restoration and using sealant ( I can't find the post now.....:mad: )....but they were doing a long term evaluation on different post cleanup sealants.....and the one that seemed to be doing the best ( longest lasting ) was a home brew mix using Minwax spar poly.
    If anyone finds that post please share ! :D
  16. Feb 27, 2012 at 6:25 AM
    rhowell
    rhowell Well-Known Member
    Robert
    Canada
    08 Indigo TRD Sport 4x4 DCSB
    -Leather with Heated seats -AFE cold Air Intake -DE-jr Rims -Upper and Lower grills from Black Diamond Fabrication -Light bar behind grill -Hella Black Magic Rallye 1000 lights. -OME lift cw Dakar leafs -LR Upper control arms -Rosen duel DVD headrests -Nfab steps -leer canopy
  17. Feb 27, 2012 at 6:38 AM
    rhowell
    Robert
    Canada
  18. Feb 27, 2012 at 1:35 PM
    24medic
    24medic Member
    Kevin
    Nor cal
    Sealant mequirs m20. One of my buddies used couple coats of clear coat it looks good. I'm not much of a painter
  19. Jun 28, 2016 at 6:44 AM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    I have just a little bit of haze on top if the headlights. Going to use this method and some sort of sealant on the entire thing. Thanks!
  20. Jun 28, 2016 at 7:22 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Just buy new headlights. I tried the 3M kit on my mom's old Buick and was not impressed. Even putting some UV resistant wax on them only delayed them fogging again. Several friends have had the same experience including those who used different kits. Considering how important good headlights are I'm just going to suck it up and buy new OEM lights whenever I get back to the US (my '05's lights are fogging as well).
