HeadLight Restore
Discussion in '2nd Gen. Tacomas (2005-2015)' started by baldy54, Feb 14, 2012.
  1. Jun 28, 2016 at 8:34 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    What can be done to prevent the hazing as to not run into this problem? My headlights are fine but would like to avoid this if possible.
  2. Jun 28, 2016 at 9:12 AM
    tacoman00
    tacoman00 Your Average Joe
    Rockville, MD
    2021 TRD Off-Road DCSB
    Toytec BOSS 2.0 lift, 18x9 Fuel Rebels, 32” BFG AT K02.
    I can honestly say that no matter what you use, it will never get it back to how it was before the oxidation came about. If you use any of those cleaners it clears up for a while but comes back worse. Go ahead and just buy new headlights if it bothers you that bad.
  3. Jun 28, 2016 at 10:53 AM
    LUNCHBOX66
    LUNCHBOX66 Well-Known Member
    Eric
    2012 white tacoma prerunner
    None so far
    @baldy54 the headlights have to be color sanded and clear coated.
  4. Jun 28, 2016 at 11:53 AM
    Jlop91
    Jlop91 Active Member
    Javier
    Calgary, AB
    2015 Toyota Tacoma TRD sport and mkiv supra
    3 inch lift, 285 65 bfgoodrich tires on 18 inch LRG rims, rigid led light bar, trd skid plate
    Depending on the hazing I would get wet sand paper start with the less aggressive one take your time. Clean it and If the hazing is gone use rubbing compound then finish with polishing compound. If you have a buffer the better. Just make sure you finish the wet sanding with a really fine grit. A detail shop recommend me to do it this way and the results were really good.
  5. Jun 28, 2016 at 12:03 PM
    DC-USAF
    DC-USAF Well-Known Member
    Dale
    WNC
    2015 SR5 Access Cab 4x4 V6
    TRD PRO Grill, mobtown offroad recovery bar, SCS Ray 10's
    If your a Sam's club member they were doing headlight restoration for $29.95 and it came with a 5 year warranty.
  6. Jun 28, 2016 at 7:29 PM
    heedfulCrayon
    heedfulCrayon Member
    2006 Speedway Blue Tacoma SR5
    Using the headlight restoration kits where you have to polish the headlight actually takes off the factory coating that protects it in the first place. Try getting a rag, spray it with a ton of bug spray (with high deet) and wipe the headlight with that rag. You would be surprised how clean they come out looking!
  7. Jun 29, 2016 at 10:21 AM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    might try this since it's just barely forming at the top right now. So this doesn't take off the protective coating from factory?
  8. Jun 29, 2016 at 10:45 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Installing headlight protection film after restoration will protect from re-oxidation.
  9. Jun 29, 2016 at 10:51 AM
    heedfulCrayon
    As far as I know it doesn't. I think it is just really good at getting bug guts off your headlights :)
  10. Jun 29, 2016 at 10:56 AM
    ENZO99
    ENZO99 Well-Known Member
    Vince
    SOCAL
    SPORT
    Bed Mat, Snugtop Sl. Gentex, Rock Sliders by shmellfab
