headlight restore?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bsb120, Feb 27, 2013.
  1. Feb 27, 2013 at 9:18 PM
    bsb120
    bsb120 [OP] Well-Known Member
    Bradley
    Easley, South Carolina
    2000 Tacoma PreRunner SR5
    painted grill and emblem, led taillights and taglight, BrushGuard, spyder auto projectors, ooga horn, 2 Memphis 12" sub w/ 500watt amp,pheonix gold 6.5s, ans tweeters custom fit in doors
    my buddy had a guy come out and restore his headlights he slightly sanded them and then sprayed something on them and they look better then new, any idea as to what this could be? or any idea how to fix terrible looking headlights?
  2. Feb 28, 2013 at 6:18 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Replacement headlights are cheap now days. Most people who restore their headlight and seal them still say they turned yellow after a period of time. Buy a new set and seal them with a sealer.
  3. Feb 28, 2013 at 6:32 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Go to any local detail shop if you want them restored... Id rather just buy a new set though
  4. Feb 28, 2013 at 6:52 AM
    Devout
    Devout Well-Known Member
    Seattle
    03 TRD 4X4
    None yet
    I used vinyl window swirl remover on mine.
  5. Feb 28, 2013 at 11:58 AM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    I polish mine every few years, but I already have the polish and associated gear (pads, buffer etc.) because I'm in the business.
    I agree with the others; price a replacement first.
    If you were local, I'd polish your headlights for free; it's that easy once you've done it a few times.
  6. Feb 28, 2013 at 5:43 PM
    bsb120
    Bradley
    plishandwax.com what do you use?
  7. Feb 28, 2013 at 5:47 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    The best way to polish them back up is sanding, clear coat, and a buff job. If you just sand and polish there is nothing to protect the lens anymore. You need a UV protectant.
  8. Feb 28, 2013 at 7:02 PM
    Gooch
    Orange County CA
    Rotary buffer, polish and a wool pad.
    I use CSI Cut N Polish, but any quality polish will work. Not too long ago I used Meguiar's M205 and that worked great.
    If headlights are REALLY trashed, I recommend wet sanding them first, otherwise polish on a wool pad works fine.
    If you don't need to sand, the whole job takes maybe 10 minutes, including cleanup. Actually a little longer if you mask, which I would do on someone else's vehicle. :)
  9. Feb 28, 2013 at 7:10 PM
    Gooch
    Orange County CA
    I agree that they will not last as long without some sort of coating, but depending on conditions, they can last years without fogging up again.
    Unlike paint, headlight lenses are really thick so you can polish them over and over and over and never go through.
    Mine are due again and I did them in 2007 and then again in 2010. But my ride is garaged.
  10. Mar 1, 2013 at 6:55 PM
    bsb120
    Bradley
    ?hmm. well can you buy the csi anywhere besides online? what about plastix?
  11. Mar 2, 2013 at 9:25 AM
    Gooch
    Orange County CA
    CSI is available in some paint shops but not in your typical retail outlet.
    I haven't tried the Plastix kits, but some people like those and other headlight kits. There are a lot of options out there.
  12. Mar 2, 2013 at 11:39 AM
    tacoma04
    tacoma04 Laissez les bons temps rouler
    Bruce
    Northern Louisiana
    2007 DCSB SR5 4X4
    I just finished using the Meguiars Heavy Duty Headlight Restoration Kit and it worked great on four headlights. They were in pretty bad shape.
    You start off wet sanding the lens with 1000 grit pad and then move to wet sand with the 3000 grit pad and then use the paste with the provided attachment for your drill. After that you put on the UV protectant and you are done. Meguiars says the UV protectant should be reapplied every three months.
    I will see how it holds up. But they look really good now.
  13. Mar 2, 2013 at 1:36 PM
    Gooch
    Orange County CA
    How easy is it to apply the UV protectant?
    I don't mean to sound like I'm bagging on Meguiar's, because I actually like several of their products, but every three months sounds like like a lot, unless it is really easy.
  14. Mar 2, 2013 at 8:20 PM
    bsb120
    Bradley
    i bought some bluemagic lens cleaner and meguiars uv selant i will try it in the morning and let yall know the results
  15. Mar 3, 2013 at 5:07 AM
    tacoma04
    Bruce
    Northern Louisiana
    2007 DCSB SR5 4X4
    The protectant is easy to apply. Put some on a cloth and wipe it on. Then buff it off. It isn't a liquid, so it doesn't run. It is a thinner paste you squeeze out of a plastic bottle.
  16. Mar 3, 2013 at 4:38 PM
    bsb120
    Bradley
    i used the two items i mentioned yesterday, and they worked great never seen my headlights shine like they do now, I also used this same method on my mothers cr-v today and it worked wonders on it too, im sold on bluemagic and meguiars
  17. Mar 3, 2013 at 4:50 PM
    Q Source
    Q Source Well-Known Member
    California
    04 PreRunner
    Supercharged, TRD Headers, URD 7th/SHORTIE 800cc injector, Snow Performance Water/Meth Kit, Deaver FJ59, Icon UCA, Fox Extended Travel Remote Resi, TG Front and Rear Bumpers, Deckplate Mod
    I've had good luck with the 3M brand headlight restorer.
    One thing I did as well was purchase the weathertech headlight film, it's just like clear helicopter tape cut to fit all the headlights, major pita to put on but it will keep the plastic from oxidizing, or at least it has for 9 California months.
  18. Mar 6, 2013 at 8:34 PM
    4Paws
    4Paws Active Member
    Scott
    Texas
    '04 PreRunner
    No before and after pics? ?? Shame on you sir.
