Headlight switch removal info needed.
Discussion in '1st Gen. Tacomas (1995-2004)' started by FARMERBUCK, Nov 4, 2012.
  1. Nov 4, 2012 at 7:15 AM
    FARMERBUCK
    FARMERBUCK [OP] Looking for answers.
    Buck
    Monticello, Ky
    Stock 11 TRD Sport
    None yet, want steps and bull bar possibly.
    97 Taco and I need a how to on changing the headlight- turn signal switch, would appreciate any info.
    Edwin1977 likes this.
  2. Nov 4, 2012 at 7:29 AM
    Madjik_Man
    Colorado Front Range
    It looks like it's just two screws holding it in place (see attached)
    Just remove the trim around the steering column and you can get to it.
    • comp.pdf
      File size:
      22.4 KB
      474
  3. Nov 4, 2012 at 7:51 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Also once you get those screw outs, nice thing is there are no wires you have to cut. The headlight switch has an integrated electrical harness that you just unplug. Then you just plug the new one in, screw in and done. Takes only 2 minutes to change out once you have the plastic from the steering column off.
    If you turn your lights on and they go black, then this is your solution after checking the fuses. The headlight switch assembly only costs $50 for an aftermarket one.
  4. Nov 5, 2012 at 2:50 AM
    exminnesotaboy
    exminnesotaboy Well-Known Member
    Maple Grove, MN
    01 Tacoma 4x4 V6 SR5 TRD Xtra Cab
    Bilstein 5100's / OME 881's / Wheelers 5 leaf pack / Level8 MK6/ 265/75-16 Bridgestone Dueler tires
    I pulled one from a junk yard for 6$. Bring your old one with you as you will find that other Toyota's are the same. However, some have a slightly different bend in the stalk itself. The one I am using is pulled off a Corolla and it's been going strong for 1 year.
  5. Nov 3, 2017 at 7:15 AM
    Tacoramirez67
    Tacoramirez67 New Member
    Ismael
    2001 Maroon Tacoma TRD
    Ko2 tires and debadg
    How about from a 96 tacoma with no auto-headlights?
    tacomakid96 likes this.
