Headlight system and pre collision system warning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WanderingKris, Apr 13, 2025.
  1. Apr 13, 2025 at 4:13 PM
    WanderingKris
    WanderingKris [OP] Member
    Kristy
    2019 Silver Tacoma 4wd
    My son borrowed my 2019 Tacoma for a few weeks and I get it back to find warning lights saying there is an issue with the headlight system and PCS. Got a fuse tester to test all fuses and the 3 right next to each other will not light up the tester. 4wd , ECU IG No 1 and ECU IG No 2. Truck runs fine other than can’t use cruise control because of these warnings. I even changed the fuses and still nothing.
    he says it started when he went through the car wash before bringing it home.
    Any thoughts?
  2. Apr 13, 2025 at 4:19 PM
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    Before even reading the last part I knew it was something with water intrusion.
    what was he doing before the car wash? the car wash alone shouldn’t have fried anything, plenty of folks on here hit the car wash frequently without problems. The only way that could possibly lead to your issues is if the fusebox was submerged or the cover was off. Any shot he took it mudding or did some sort of water crossing (intentional or accidental) but didn’t tell you?
    If it’s running fine and you don’t have any obvious misfires then it’s definitely something electrical
    Chew and TheWildMan like this.
  3. Apr 13, 2025 at 4:33 PM
    WanderingKris
    Kristy
    Based on the amount of mud I cleaned out - quite possibly. Is this a dealer fix or anything I can do myself. Anything for me to try ?
    Kristy
  4. Apr 13, 2025 at 4:44 PM
    Clearwater Bill
    Billy
    Largo Florida
    Depends on the actual problem of course.
    IMHO son needs to be bearing the burden here. It's fair for you to expect to receive the vehicle back the same condition you loaned it in. And I'd guess it wasn't full of mud when he picked it up.
    Speaking of which, exactly where was this mud? Floorboards, as in foot traffic? Or elsewhere?
    Have you examined the area behind the grill? Are the condenser fins filled with mud?
    Chew and TS4x4 like this.
  5. Apr 13, 2025 at 4:47 PM
    TS4x4
    2018 TRD Offroad
    Oh boy. Again, you can definitely take a taco through some mud and water, but depth and duration are important factors. If I had to guess it sat in something wet for longer than it should have and the push connections on the PCS, headlights, and maybe something else got soggy and then corroded. Also if he got water up that high then the wire bundle itself could have some other failure points. Woof.
    A dealer is going to tell you to replace everything when hopefully there’s a much cheaper solution. I would go to an independent shop first that’s reputable and knows Toyotas.
  6. Apr 13, 2025 at 5:39 PM
    WanderingKris
    Kristy
    I don’t think he left it sitting in water or mud. I have an AirTag in it and it was never left anywhere for a long time.
    I took it to the car wash after I got it back. Mud was mainly up in the fender wells and tires.
    I saw the truck nearly every day when he had it. He used it for work and was on “B” level roads which are basically mud.
    Guess we will see what the shop tells me.
    t0p_d0g likes this.
  7. Apr 13, 2025 at 6:08 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    If your son will tell you where and how it happened it might be easier to diagnose the problem and make the repair more reasonable.
  8. Apr 13, 2025 at 6:25 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Make sure the grille garnish in front of the millwave radar is clean. Make sure the windshield is clean in the PCS camera area (it's to the right of the rear view mirror). The automatic headlights use photo sensors on the dashboard to detect light, so make sure they aren't covered. Did you pop off the dash speaker grilles at any time in the past (say, for running dash cam wiring down the A-pillar)? If so, check the photo sensor wire connector is secure.
    Other than that, you'll want to scan the PCS system and body control module (BCM) for codes rather than shooting blind.
    Clearwater Bill and t0p_d0g like this.
  9. Apr 14, 2025 at 12:24 PM
    WanderingKris
    Kristy
    The shop called , code C1AA0. Said front camera needs replaced. $2300.
    I will see what I can find about doing this myself. Until then I will just not have cruise control and alerts popping up.
  10. Apr 14, 2025 at 3:42 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
