Headlight trouble
Discussion in 'Lighting' started by wsfisherman189, Sep 1, 2016.
  1. Sep 1, 2016 at 10:27 AM
    wsfisherman189
    wsfisherman189 [OP] Expert
    Jeffrey
    Newport, ri
    2010 Black Tacoma 6inch Lift
    6 inch fabtech Aero turbine 2525xl CB Radio Mag-lite Mod bhlm projectors raptor grill in dash head unit ultra gauge urd cai maf calibrator 10 inch sub fishing pole holders
    So I have a 2010 Tacoma with retrofit hids. When I go to turn my headlights on, the fogs, taillights, and little yellow lights in the corner of the lights turn on but not the headlights. I have to flip from on to off a few times, then the lights turn on. I have checked all connections and the ground and all seems to be fine....do I need new ballasts, or how do I troubleshoot? Any help is appreciated. Thanks you
  2. Sep 1, 2016 at 12:46 PM
    CaptainMorgan
    CaptainMorgan Custom headlight retrofits
    Mesa, Arizona
    2014 White Tacoma TRD Sport
    17 inch Black Rhino Rockwell Wheels, BFG 275/70/17 Ko2 Tires, 3 Inch Rough Country Front lift 2 inch Rough Country Rear Lift
    what brand HID parts do you have?
  3. Sep 1, 2016 at 12:51 PM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    First thing. Check to see if you have a HID wiring relay. Then check the actual relay to see if it's "clicking" on and off with the switch. 9 times out of 10 its just a corroded relay thats sticking. If that seams to be fine, use a volt meter or test light at the ballast plug to see if your getting power to the ballast. If both lights are acting similar I would say its an old relay.
  4. Sep 1, 2016 at 12:54 PM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    change the title of the thread to HID Help, or something like that. thread with "HELP" as title sux balls, I checked it thinking you were in danger, or needed a pull out of somewhere
    VangaSTL likes this.
  5. Sep 1, 2016 at 1:02 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I just page The Chosen One.
    @tcBob
    tcBob and JimboAnz[QUOTED] like this.
  6. Sep 1, 2016 at 1:03 PM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    :thumbsup:
  7. Sep 1, 2016 at 2:16 PM
    wsfisherman189
    Jeffrey
    Newport, ri
    I got them from the retrofit source. I installed them about 4 years ago and they have been fine. When i turn my lights on, the realys dont make a sound. When i turn the switch a
    On and on a few times, then the lights turn on and the ballasts make a sound....i just dont want to be stuck out at nught with no lights....so is it a ballast problem? Or corrosion?
  8. Sep 1, 2016 at 2:17 PM
    T4RFTMFW
  9. Sep 1, 2016 at 2:23 PM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Sounds like you have a corroded relay. try turning on the lights and then tapping the relay to see if it clicks. If it does you definitely have a worn relay and it needs to be replaced
  10. Sep 1, 2016 at 2:56 PM
    wsfisherman189
    Jeffrey
    Newport, ri
    Okay ill give that a shot and let you know
  11. Sep 4, 2016 at 9:59 AM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    Hey man! Sorry for such a delay. Been super busy with school and such. But yes, you can isolate the problem by plugging your ballast straight to your battery. If all that works, it sounds like you have a relay problem. If you purchased the 35w system through TRS, you're still within warranty time frame. Call us Tuesday and ask for Jimmy. I'll send one out for you!
    T4RFTMFW likes this.
  12. Sep 5, 2016 at 5:18 AM
    wsfisherman189
    Jeffrey
    Newport, ri
    So how do i go about plugging the ballast straight to the battery? Do you have any digrams that i could follow step by step? Thanks
  13. Sep 6, 2016 at 11:48 AM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Assuming you are using an aftermarket wiring harness, you should be able to plug the ballast straight into the OEM plugs that the old incandescent bulbs "used" to be plugged into
  14. Sep 8, 2016 at 5:32 AM
    TRSJimmy
    Jimmy
    Gainesville, GA
    You can simply use a pigtail with alligator clips or something similar and plug the + and - to the battery.
  15. Sep 15, 2016 at 4:06 AM
    wsfisherman189
    Jeffrey
    Newport, ri
    ALL FIXED! I ORDERED A NEW HARNESS AND NOW IT WORKS FINE! THANKS FOR ALL THE HELP GUYS
  16. Sep 28, 2016 at 5:50 PM
    thebaker
    thebaker Well-Known Member
    Byron
    NorCal
    Upgraded to a 3rd gen
    Never ending......$$$
    I'm going through this same problem now. However, it's just my left headlight. Sunday, the left headlight was flickering and wouldn't turn on. While driving home from work it finally came on. The past two days the lights wouldnt turn on. The passenger side headlight is working fine. I checked the connections and everything seems tight and in order. If i'm just having problems with the drivers side headlight canit still be the relay? or would I be having a problem with both headlights if it was the relay?
  17. Sep 28, 2016 at 7:30 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Are you turning on the lights before or after you start the car. I know on mine the ballast won't start the passenger bulb because of fluctuating voltage. Once I start my truck I then wait a couple seconds before I turn on my headlights. I don't have DRL's though so that could be a problem. You may need to run a new HID wire harness to bypass the low voltage from the stock headlight harness.
  18. Sep 28, 2016 at 8:23 PM
    thebaker
    Byron
    NorCal
    I always turn my headlights on after I start my truck. I don't have DRL. They have been working flawless for years and just this week I started having problems.
  19. Sep 29, 2016 at 6:18 AM
    wsfisherman189
    Jeffrey
    Newport, ri
    I replaced the wiring harness, it was like 30 dollars and now it works fine. I could be a loose connection in the box or corrosion...
    thebaker likes this.
  20. Sep 29, 2016 at 6:34 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Try flipping the ballasts and see if the problem follows to the other side. If it does then it's the ballast.
