Headlight vent caps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NBourque, Aug 15, 2023.
  1. Aug 15, 2023 at 9:00 AM
    NBourque
    NBourque [OP] Well-Known Member
    Nick
    Maine
    ‘21 PRO
    Passenger side headlight has been fogging up lately. Not OEM. TYC brand. I dried out the light completely with a vacuum and I’ve tried both taking off the vent caps and running them in to no avail. They’re 2 little plastic caps that I’m assuming are vents? They don’t seem to do much.
  2. Aug 15, 2023 at 5:30 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Did you run a bead of silicon (use fish tank silicon) around the main seal area as the aftermarkets all leak at some point.
    You may want to use a heat gun to ensure its really dry in there as many nocks to hold moisture.
    You really have to take them out to seal and dry then still good luck. Only the OEM seem to last if your DRL don't burn them first (if change to led then resistor needed).
    Those vents I've seen in several configurations and I think water running down the back or underhood side may get into them.
    Make sure the headlight to hood seal is still there and no gap so water is forced in and over the headlight. Hood height can be set with the rubber bump stops and when you install the headlight it has some play.
    Hope it helps.
  3. Aug 17, 2023 at 2:25 PM
    NBourque
    Nick
    Maine
    ‘21 PRO
    Thanks for the reply mud dog.
    anyone use silica gel packs to displace moisture? Where do the packs go? Right inside the headlight housing or near the light boot?
  4. Aug 17, 2023 at 2:29 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    What's the problem? If the lights are vented to atmosphere, they will fog up and clear up eventually.
  5. Aug 17, 2023 at 2:59 PM
    NBourque
    Nick
    Maine
    ‘21 PRO
    They clear up a bit during the day but not completely
