Headlight weatherstrip
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pacificclam, Aug 31, 2023.
  1. Aug 31, 2023 at 7:01 PM
    Pacificclam
    Pacificclam [OP] Well-Known Member
    Carl
    Hawaii
    2010 Tacoma 4x4 Access cab
    6” pro comp lift Kings Coils and Shocks 700lbs Element UCA Atlas Leaf spring kit 17x9 stealth custom series ray 10s -38 33x12.5 toyo open country mt Tom woods driveshaft CSF high performance radiator 4.88 GEARS
    I just replaced my headlights and Im wondering where to buy the rubber weatherstripping that sticks to the top of the headlight? Its that rubber piece in between the top of the headlight and the hood. Let me know what you guys have used. thanks!
  2. Sep 1, 2023 at 8:49 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    With my OEM replacements, it came with the headlight assemblies.
    Pacificclam[OP] likes this.
  3. Sep 5, 2023 at 11:14 AM
    Pacificclam
    Carl
    Hawaii
    Ya unfortunately I didnt go OEM...
  4. Sep 5, 2023 at 12:05 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Pull it off the old ones and silicon glue and seal them back on new ones.
    I did that and if you leave a gap between the light and hood in heavy rain you may get water flowing in and down into the rear light vents so moisture inside.
    The hood rubber bumpers can be adjusted to get min gap as well.
    Hope you sealed the aftermarket headlight seams or they will leak - many posts on that.
  5. Sep 5, 2023 at 12:07 PM
    Pacificclam
    Carl
    Hawaii
    Good idea. Ya i sealed the new headlights with silicone all around. They have been on a month and no leaks yet.
