Headlight wiring - positive or negative switched
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Firn, Oct 9, 2022.
  1. Oct 9, 2022 at 7:52 AM
    Firn
    Firn [OP] Well-Known Member
    White OR
    I have seen this discussed before but the heck if I can find it now.
    For the high beams and low beams are the positive or negative switched?
    I wish to add a relay so auxiliary lighting is enabled with the high beams so I need to know if I enable a positive trigger or a ground trigger.
    Thx
  2. Oct 9, 2022 at 9:50 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  3. Oct 9, 2022 at 10:01 AM
    caribe makaira
    Caribbean, Puerto Rico
    The headlights (low & high) relays are negatively switched, but the headlights are positive. So add-a-fuse to HIGH and one for LOW, for positive trigger to added relays.
    vicali and Firn[QUOTED][OP] like this.
  4. Oct 9, 2022 at 10:04 AM
    RyanDCLB
    4/19 DCLBOR
  5. Oct 9, 2022 at 10:11 AM
    Firn
    White OR
    RyanDCLB[QUOTED] likes this.
