Headlights Adjustment.
Discussion in 'Lighting' started by Ana, Mar 8, 2013.
  1. Mar 8, 2013 at 12:55 AM
    Ana
    Ana [OP] Member
    2009 Tacoma
    Is there any way I can adjust my headlights LOWER? Seems high, and some oncoming traffic cars would flash me with their hi-beams
  2. Mar 8, 2013 at 12:57 AM
    ToyotaTacoma4Ever
    ToyotaTacoma4Ever Get Boosted
    Eric
    Alberta
    Supercharged Tacoma Sport
    Check Out The S/C Build
    There's two silver adjustment screws in the back of the headlight housing, one for horizontal movement (left & right) and one for vertical movement (up & down)
    Have you tried that??
  3. Mar 8, 2013 at 1:02 AM
    Ana
    Ana [OP] Member
    2009 Tacoma
    No I haven't. I seen the screws, I just didn't want to mess with anything before asking.. Thanks !!
  4. Mar 8, 2013 at 1:05 AM
    ToyotaTacoma4Ever
    Eric
    Alberta
    Yeah no problem, just twist them one way to find out which one controls which direction and go on from there. Make sure your on a flat surface for you can see your beams on the wall
  5. Mar 8, 2013 at 1:08 AM
    Ana
    Ana [OP] Member
    2009 Tacoma
    Will do! Thanks again!
  6. Mar 8, 2013 at 1:59 AM
    jdk52
    jdk52 Bro do you even 'Merica?
    Utah
    11 SR5
    3 inch OME lift kit, rear diff breather mod, cb install, sliders, brute force fab front end.
    Drive as close as you can to the wall and mark a spot inline with the headlights with tape ----------------------- then drive back about 20 feet and get them just below that line.
