Headlights adjustment
Discussion in 'Lighting' started by Bluelyfe, Sep 8, 2014.
  1. Sep 8, 2014 at 12:31 PM
    Bluelyfe
    Bluelyfe [OP] Well-Known Member
    Should I call the dealer to see if they can align my lights? I just put in Hids in the other day, keep getting high beamed and for everyones safety maybe I should lower the lights? :eek:
    I tried finding the screw to change the angle but it looks like I have to take my lights apart to do this?? Anyone done this before? or did you just go to the dealership and do they do this for free even though I have aftermarket bulbs?
  2. Sep 8, 2014 at 12:44 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    You're out of luck if you put an hid bulb in a reflector housing. Cant aim that at all, no matter how hard you try. If you want to run HID then i suggest a retrofit. Check out the kits at theretrofitsource.com
  3. Sep 8, 2014 at 12:50 PM
    Bluelyfe
    Really you cant even try to aim them down?
    I bought the Hid from them... dang should have went with the retrofit...
  4. Sep 8, 2014 at 12:56 PM
    toyotatruck11
    toyotatruck11 Well-Known Member
    Alberta canada
    Tacoms SR5, tow package undergoing transform
    The adjusters are located on the back of the light housing. One for up and down and one for side to side. Always end your adjusting with a counter clockwise adjustment to lock it in place. A shop manual has the protocol in it.
  5. Sep 8, 2014 at 12:57 PM
    joeyzoolander
    joeyzoolander Well-Known Member
    Joe
    California
    I just lifted my truck and had to re-align the headlights. there are two adjustment screws on the back of the headlight with little black caps on them. The bottom one controls the up and down and the top one is left and right. I unbolted the windshield wiper res. so i could fit down in there. I had a socket on a pneumatic drive so it was pretty easy. its tough to get down in there but it worked.
  6. Sep 8, 2014 at 12:58 PM
    Bluelyfe
    I found the top one, but thats for horizontal adjustment. The bottom ones are for the vertical ones, but I have a hard time finding it and I feel like you have to take your headlights off to get to them? Idk I tried last night and I gave up
  7. Sep 8, 2014 at 1:00 PM
    joeyzoolander
    Joe
    California
  8. Sep 8, 2014 at 1:01 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Well, i suppose its not impossible. But, i would recommend you put the stock blubs in until you get a projector. But that's just me.
  9. Sep 8, 2014 at 10:30 PM
    NoSilverBullet
    NoSilverBullet N60 member
    Northern Canada
    2012 AC 2.7 MT 4wd
    Old Man Emu suspension: 884x coils, Dakar leaf pack, Nitrocharger Sport shocks. Cruisin Offroad bolt-on sliders. Relentless Fabrication aluminum front and mid skid plates + steel transfer case skid. SnugTop Hi-Liner "Sportsman" canopy. Hella Rallye 4000i Xenon (flood beam).
    ^^^ This. There is a reason why putting HID capsules in headlights designed for halogen bulbs is illegal. You will not be able to adjust that properly.
  10. Sep 9, 2014 at 10:15 AM
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    No matter how much you adjust, the light output will still be scattered and blind oncoming motorists.
  11. Sep 9, 2014 at 3:31 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Dude, the stock halogen bulbs have a little "shield" under the low beam filament. This causes the light to be reflected off of only the top half of the reflector bowl and produces a nice sharp "cut off" line. This prevents light from shining up in the faces of oncoming drivers.
    The high beam filament sits closer to the base of the bulb and is unshielded, allowing it to utilize the entire reflector and shine light everywhere. This is why people usually do not drive with their high beams on all the time.
    Your HID bulb is pretty much acting like the high beam filament and reflecting light off of the entire reflector. You can make all the adjustments you want but that will not change this simple fact. :cool:
