Headlights auto shut off?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by norcaltaco1, Feb 6, 2012.
  1. Feb 6, 2012 at 8:23 AM
    norcaltaco1
    norcaltaco1 [OP] New Member
    I'm just wondering if the headlights will remain on if I accidently forget to turn them off and turn off the engine and leave the car? I read that they automatically shut off once the door is closed? I have a 2010 double cab if that makes a differnce? thanks!
  2. Feb 6, 2012 at 8:24 AM
    nut
    nut she'll ride
    Patrick
    Eustis, FL
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    they do shut off. just try it :rolleyes:
  3. Feb 6, 2012 at 8:26 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Yep X2. Turn off truck, as soon as you open the drivers side door, they go off. Come back on when you start the truck if you leave the switch to on. Does not hurt anything if you want to just leave the switch to on.
  4. Feb 6, 2012 at 8:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    When you turn off teh truck, and open the door, they should turn off. At least on mine they do.
  5. Feb 6, 2012 at 8:31 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    He wants to know if you walk away from the car with them on, will they shut off automatically? I think so. Try it!
  6. Feb 6, 2012 at 8:33 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Now I'm :confused:
  7. Feb 6, 2012 at 8:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I thought I read in teh manual, that they turn off after 2 mins.
  8. Feb 6, 2012 at 8:35 AM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    this!! i don’t really ever turn mine off. lol day time they are even on so people can see me better. :D but like chris said when you open the door they will turn off.
  9. Feb 6, 2012 at 8:37 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    So, meaning if the engine is off and then you turn the lights on? Didn't know that. But then again I wouldn't turn them on with engine off and then just walk away. Not sure what the reason for that would be.
  10. Feb 6, 2012 at 9:46 AM
    dYL0n
    Dyl0n
    New Orleans, LA
    I have 2 mins to spare. BRB. I'll let you know what happens.
  11. Feb 6, 2012 at 9:49 AM
    upthemaiden
    upthemaiden Well-Known Member
    Josh
    Pittsburgh PA
    06 Access cab SR5
    Just bought it!
    I think he means if they're running when the car is turned off, at least that's how he has it worded. I always leave mine on as well. I've been confused ever since I saw someone do a write up for daytime running lights on their truck. It's basically the easiest mod you can do to your truck, just twist the knob two turns and you're done. No need for a write up.
  12. Feb 6, 2012 at 9:54 AM
    dYL0n
    Dyl0n
    New Orleans, LA
    Eh I just tried it. Didn't cut off after 2 mins. Looked in the manual too... Hmmmmmmm more research to come.
  13. Feb 6, 2012 at 9:57 AM
    oZmonKey
    oZmonKey Big Metal Hubajube
    Northern Colorado
    Black 98
    Unknown Spacer Lift.
    2011
    I always leave mine on.
    My general routine is stop, turn off engine, take key, open door. The lights go off when I open the door.
    Couple weeks ago, I stopped in the dark to get a bite to eat. I had to pee really bad, so I wasn't thinking straight and when I stopped, I turned the lights off after I took the keys, but before I opened the door. Then I was like, why turn them off? They turn themselves off, so I turned them back on. Then when I got out, they stayed on. They were still on 15+ minutes later (long enough for me to pee, order fast food, and eat it).
    So, order of operations counts.
  14. Feb 6, 2012 at 9:59 AM
    dYL0n
    Dyl0n
    New Orleans, LA
    I really don't feel like sitting outside staring at my headlights for 5 mins. I read in the manual, it says "don't leave your headlights on for an extended amount of time without the truck running". Which basically indicates to me, there's no timed cut-off. Maybe an accessory cut off when the battery drops below a certain voltage, I know some vehicles have this. It allows just enough juice in there to let the engine start.
  15. Feb 6, 2012 at 9:59 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    LOL, Well the day time running lights are different, the lights where the turn signals are stay on with the trucks that have the DTRL.
    Hmmmmm.
  16. Feb 6, 2012 at 10:01 AM
    Surferdude
    Surferdude Erich
    Erich
    Grayslake, il
    '11, DC SR5, 4x4
    ProEFX Tonneau cover, Coverking seat covers, Weathertech front floor liners, Coverking Cab Cover, Westin nerfs, in transit...
    Found this out the hard way.
    Engine running, lights on:
    -Turn off truck, remove keys and soon as you open the door, lights go off.
    -Return to truck, open door, start the engine, lights come on.
    -Turn off truck and leave to accessory to listen to radio for a few.
    -Turn off headlights manually
    ---Ready to leave truck, remove keys, turn on lights.
    ---Open door and walk away.
    ---Return 3 hours later and lights are still on!
    Basically, RTFM. The manual explains it nicely. :D
    So if the engine is off and you either turn on the lights manually, or turn them off/on, they will remain on when you leave.
    Therefore, I ALWAYS leave mine on and don't shut off. If I'm sitting in the truck to listen to the radio, I turn the lights off and leave em that way until I'm ready to start the truck again.
  17. Feb 6, 2012 at 10:01 AM
    dYL0n
    Dyl0n
    New Orleans, LA
    I'm going to say no.
  18. Feb 6, 2012 at 10:02 AM
    gooch14
    gooch14 Well-Known Member
    Kyle
    Michigan
    2011 Blk DC Taco SR5 4x LB
    Bestop, Child Seats, petrified french fry, dog hair, empty Mtn Dew cans cracked windshield, scratches.
    I reached from the passenger side and turned my truck off once, lights ran all day because the drivers door was never triggered.
  19. Feb 6, 2012 at 10:03 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Drivers door is the only switch and it only works with key off. Don't be like me, start your truck from the passengers side, shut it off, then forget about it. I ran my battery dead because my lights were on. I was like, WTF, I don't believe you haha.
  20. Feb 6, 2012 at 10:03 AM
    dYL0n
    Dyl0n
    New Orleans, LA
    I wonder if you can DRAIN the battery to nothing, by leaving the lights on?
