Headlights bulbs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Don77, Feb 18, 2023.
  1. Feb 18, 2023 at 10:05 PM
    Don77
    Don77 [OP] Member
    2010 4x4 trd sport
    Best led bulbs out there ?? 6k
  2. Feb 18, 2023 at 10:12 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  3. Feb 19, 2023 at 2:27 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    6ks are blue white and you will get flashed at.
    Depends on your budget. Above thread has many options.
    Perde H4s are a cheap upgrade a coated tip not 6k but whiter like 4k and lifetime about $15 Amazon. Been in for over 5 years still good and add some cheap Alla 9145 H10 fog bulbs and good to go. Looks like new vehicle headlight color - white not yellow or blue. The stock housing if not leaking and if buffed out works well but if you have aftermarkets focus is different on most of them so depends. Only leaves those crappy filamint DRL/blinkers to burn the housings but I never added LED and resistors.
  4. Feb 19, 2023 at 4:33 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Are you looking for performance or looks? I'm assuming just looks because as @crashnburn80 has already stated, drop in LED bulbs are a performance downgrade. Many folks are fooled into thinking they are brighter though because they flood the near field with light at the expense of distance lighting. Another fallacy is that "bluer" light is actually brighter light. Wrong again. Read the thread crash posted.
  5. Feb 19, 2023 at 5:31 AM
    mikkydee
    mikkydee My Taco 2007 DCLB 4x4 Man Truck
    Doyle
    Florida
    2007 Silver DCLB Tacoma, 4X4, 4.0 Liter, 6" lift, 20" rims, 34" tires
    6" lift, 20 " inch rims, 34" tires, billet grill, aftermarket fender flares, custom rear bumper, DVd player with backup camera, all LED lights
    dude, I wasted lots of money trying to find a good LED replacement bulbs for my OEM headlights. Complete disappointment. Went back to halogen upgrade bulbs. Anybody want some LED bulbs?
    Too Stroked likes this.
