Headlights cleaning question.
Discussion in 'Detailing' started by skyneon, Oct 13, 2010.
  1. Oct 13, 2010 at 11:44 AM
    skyneon
    skyneon [OP] Member
    99 PreRunner
    Hi, I have ordered the 3M headlight cleaning kit with pads from Amazon. The problem is, when I washed the headlights I have noticed that each one has 3 of some sort of pimples in the triangle position. When I washed them with a sponge, those pimples tore up the sponge. I am afraid they will prevent proper headlight cleaning. How do I avoid them? Should I use file/rasp to get rid of them? I hope this all makes sense, English is not my first language. :)
    Thanks in advance!
  2. Oct 13, 2010 at 11:54 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Just work around them with the 3M kit. I don't know if it would do any damage filing them down but I would risk it. Those are just the pieces of plastic left sticking up when they were formed from the factory so I don't believe they have any structural significance.
  3. Oct 13, 2010 at 11:57 AM
    skyneon
    skyneon [OP] Member
    99 PreRunner
    That is what I thought. Thanks!
  4. Oct 13, 2010 at 12:00 PM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    I think those are actually used by some of the headlight alignment systems that some shops used to have. The alignment device is supposed to make contact with those. I don't think any of the newer cars have them. Like Pugga said, you can just work around them.
  5. Oct 13, 2010 at 12:04 PM
    skyneon
    skyneon [OP] Member
    99 PreRunner
    It would be very hard to work around them because of their position specially with a buffer or such. I will just get rid of them and see if the 3M kit helps, if not I will just buy new headlights. Just wanted to make sure they are not so important. Thank you
  6. Oct 13, 2010 at 1:00 PM
    Bama_TACO
    Winfield, AL
    I used the 3m kit you are talking about on my daughter's Altima and it made them look like new.
  7. Oct 13, 2010 at 1:03 PM
    Madjik_Man
    Boulder County
    1998 Ext Cab 3.4 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    When I restored my headlights I accidentally sanded those plastic pimples down to nothing.
    It causes no harm to your headlights. It does however eat up the pads. Which isn't such a big deal except for the polishing pad. Just be careful with that last step
  8. Oct 13, 2010 at 1:12 PM
    rwcfrank
    rwcfrank Well-Known Member
    08 SR5 Prerunner
    This is a reminder to keep those lights clean at every other wash to avoid build up and degredation. I use Meguiars Plast-X
  9. Oct 13, 2010 at 2:30 PM
    skyneon
    skyneon [OP] Member
    99 PreRunner
    Great videos! Thank you all! It my order delivered by the weekend, I will get working this Sat.
  10. Oct 13, 2010 at 2:43 PM
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
    x2...used it on my wife's Jetta. I was really surprised at how good it turned out.
    and x2...I use the same!
  11. Oct 14, 2010 at 5:34 AM
    ConnYotaMedic
    ConnYotaMedic Member
    central Connecticut
    SR5
    Weathertech custom mats, TRD CAI, TRD catback exhaust, roughcountry 3"in lift, mostlikly new tires before this winter in case the northeast gets killed like we did last year.
    I have been using Plastix polish to keep the headlights and tail lights clear on my truck and former mazda, also had the clear headlight / tail light housing, the stuff works great, acts as a wax / polish for the plastic, does a nice job keeping them looking new, especially for me with the northeastern US winters, not a bad product to try out. Im not sure who makes the product but I bought it at an automotive supply shop, I'm sure its available at the big box stores, worth checking out.
  12. Oct 14, 2010 at 7:17 AM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    I use a wool pad on a rotary buffer with just about anyone's polish (System 51 Perfect Cut, CSI Cut N Polish, Meguiar's M205, etc.) and headlights come out great. The pimples don't bother the wool pad.
    You don't need a special headlight kit to take care of headlights, but if you don't already have a buffer and wool pad, they are are a good purchase.
  13. Oct 14, 2010 at 1:34 PM
    Madjik_Man
    Boulder County
    Here's mine half way through
    Passenger side done, driver's not done yet
  14. Oct 14, 2010 at 5:51 PM
    Gooch
    Orange County CA
    I hope you have that backwards. :D
  15. Oct 14, 2010 at 6:29 PM
    Madjik_Man
    Boulder County
    lol
    Dyslexia FTW
  16. Oct 14, 2010 at 7:57 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Agreed. Don't know exactly how they're used but I also heard that's what they were meant for. On new headlights they don't use those nipples anymore, they rely on the horizontal lines & the dot/circle in the middle.
