Headlights Don't Always Turn On (Relay?)
Discussion in 'Lighting' started by Tacomanator, Jul 7, 2013.
  1. Jul 7, 2013 at 10:31 AM
    Tacomanator
    Tacomanator [OP] Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Recently, I've been having to flick my headlights off and on to get them to fire. I checked all connections, grounds etc... One thing I noticed is that whenever I flick them on, the relay makes a click noise. Could it be a bad relay, ballast or something else?
    Btw, i'm running a Morimoto Mini H1 retrofit with 55w ballasts
    Thanks,
  2. Jul 7, 2013 at 1:02 PM
    Tacomanator
    Clam Slammer
    Southern Cali
  3. Jul 8, 2013 at 6:42 AM
    HighTQCummins
    HighTQCummins Instagram: stormtrooptaco
    Hank
    SE PA
    '12 SW DCSB Sport
    5% all around, derp'd wheels, FMS40, 30" E-Series, 55w 6k bi's, 35w 5k fogs
    I'd like to know what this is too, although I am not running retro's yet, they are still 55w w/ a relay and the same issue happens, sub'd for info
  4. Jul 8, 2013 at 6:52 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    It depends on how you have them wired up. I assume by retrofit you have Hi/Lo single bulb HID's. What harness are you using?
    Both lights don't fire? Then I believe it's not a ballast. It would be odd for both to go out. It does sound like a relay, now more testing needs to be done to determine if it's the stock one or the HID "controller" one.
