Headlights filled with condensation and water
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rdbtaco06, Jan 10, 2018.
  1. Jan 10, 2018 at 3:08 PM
    Rdbtaco06
    Rdbtaco06 [OP] Well-Known Member
    Russ
    2006 Toyota Tacoma 4 X 4
    Anyone know how to rid headlights of water and condensation?
    So frustrated have had to replace my aftermarket Anzo smoked headlights 3 times. I have sealed them up now I understand they have to have vents to breathe. So confused don't what to do.
    Pain in the ass.:angrygirl:
  2. Jan 10, 2018 at 3:11 PM
    16Tacos
    16Tacos Well-Known Member
    Zach
    Boston
    08 Access Cab 4x4 V6 SR5
    OME Nitrochargers w/886s & Dakars, ARB Deluxe Bull Bar w/Warn winch, RCI sliders with kick out, IFS & Mid skids, BFF Hi-clearance rear bumper, Brushed Copper 17" SCS Ray10s w/285-70 KO2s, Black OEM 16" steelies w/255-85 KM2s, Leer contractor cap w/Smittybilt overlander xl RTT, Off-Grid Engineering dual battery kit and bed power panel, Blue sea aux fuse block, Wyntner 60L fridge freezer, ARB dual compressor, Pioneer 720BT head unit, CB radio, @Matt_Gecko bed and engine bay lights, @TacomaTruckParts Dirt bike tie down bar, color matched OEM grill, A-Pillar phone mount mod, @Docloco rear seat molle panel
    I've seen silica packets suggested as a potential fix. I'm thinking of trying to find a way to put some in my retrofits before I seal them back up.
  3. Jan 10, 2018 at 3:12 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The best way is to use OEM headlights.
    crashnburn80 likes this.
  4. Jan 10, 2018 at 3:16 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Hey so I’ve had problems with aftermarket lights also. Yes I tried sealing them etc.
    My lights no longer leak I used a rubber tape to get a better seal between housing and bulbs.
    Actual headlight sealed good but the markers must not have been.
    Have not had a issue with condensation since!!
    Just my experience
  5. Jan 10, 2018 at 3:51 PM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    I'm going to need to get new headlight assemblies soon. That darn running light melt thing, I tried to get replaced by dealer but missed it by what ever time. But they did give me the part numbers to get, the question is do you want chrome or do you want the sport. Personaly when I replace I will be going OEM part #'s 81110-04210 right and 81150-04210 left which are sport I think they call it smoked(black) chrome. I also have the plane chrome #'s too if needed.
    Good luck
  6. Jan 10, 2018 at 3:53 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    https://youtu.be/0RYksDWdQZ0
  7. Jan 10, 2018 at 3:56 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Sounds like someone is low on blinker fluid
    irayfz6 likes this.
  8. Jan 10, 2018 at 4:09 PM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    It’s on sale today!!!
    Tiedie likes this.
  9. Jan 10, 2018 at 5:06 PM
    Rdbtaco06
    Russ
    Thanks all for your help and suggestions. It always seems to be the driver side headlights. I have sealed them before but obviously not good enough on the top edge.
