Headlights flicker when losing traction
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Baerskin, Jan 6, 2022.
  1. Jan 6, 2022 at 11:16 AM
    Baerskin
    Baerskin [OP] Rocking in the Free World
    Manitoba
    TRD Sport Premium 4x4
    Stock
    So it’s wintertime, my 2020 seems to have a issue with the headlights during the nighttime when I am on a slippery road.. once my traction control light goes on I can visibly see my headlights flicker a bit, but only when the traction control is on. Does this happen for anyone else? It’s not too severe but it is noticeable. Think it will get worse?
  2. Jan 6, 2022 at 11:19 AM
    Tacospike
    Two Trucks
    Never heard of this before. :confused:
  3. Jan 6, 2022 at 11:21 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Sounds like a loose grounding point somewhere.
    pltommyo, hiPSI and boston23 like this.
  4. Jan 6, 2022 at 11:23 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    My ‘13 does it on extended braking on ice. Think it’s the PCM getting scared & preparing for impact. After all, not like they can scream.
  5. Jan 6, 2022 at 11:33 AM
    GeronimoCO
    GeronimoCO Active Member
    2016 TRD Off-Road Double Cab
    It's likely just because your truck is doing like 13 things at once in an effort to correct the slippage... Does it happen while you're hearing the brakes firing off and the ecm is working overtime to regulate wheel spin and right the truck? Maybe just an intermittent dip in headlight voltage due to all the processes using up juice? Kind of like when headlights dim when the bass drops in vehicles with crazy big sound systems?
    boston23 likes this.
  6. Jan 6, 2022 at 11:45 AM
    Baerskin
    Manitoba
    Stock
    Hmmm I’ll monitor the situation! Thanks for the replies folks, I’ll go with the 13 different things happening with my truck lol .. hopefully my battery is okay
  7. Jan 6, 2022 at 11:47 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Install a set of ARB air lockers.
    pltommyo likes this.
  8. Jan 6, 2022 at 11:51 AM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    I had an 2018 sport that did the same thing, I believe its the abs module drawing enough current to draw down the electrical system some.
    Or it's a feature to let oncoming traffic know that you out of control and to stay clear lol
    na8rboy and Chew like this.
  9. Jan 6, 2022 at 11:55 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Voltage drop from the pump and solenoids placing extra demand on the electrical system. If it's new or severe it may be an indication of something unhealthy in the electrical system such as a weak battery or poor system ground.
    Toy_Runner, Skydvrr and boston23 like this.
  10. Jan 6, 2022 at 12:59 PM
    Midnight beauty
    Midnight beauty Well-Known Member
    White mountains AZ
    2020 midnight black Tacoma TRD Sport
    I’ve had my 2020 sport for two winters now and I have had the traction control kick in several times but have never had my lights flicker.
  11. Jan 6, 2022 at 1:15 PM
    bornxbackwards
    bornxbackwards Well-Known Member
    Bruno
    Sherbrooke, QC
    2021 MGM Tacoma SR5 4x4 DCLB
    Debadged, black sumos, brake controller.
    Mine does that. I attributed that to the fact that with now that I work from home, I don`t drive it enough and battery is not fully charged. Way too many short trip to school for kids at less than a mile.
    Will try to monitor if it`s still the case when I drive longer and battery can charge up.
    edit: it`s not really flicker, but you see they lose a bit of power.
  12. Jan 6, 2022 at 3:41 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    That is really rough on the battery, shortens life quite a bit. You can get a NOCO battery tender for around $30, put it on overnight once a week.
  13. Jan 6, 2022 at 3:52 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    The ABS modulator draws a lot of current to pulse that brake fluid that fast. Still get your charging system checked, Alternator, battery, check all ground wires.
  14. Jan 6, 2022 at 5:24 PM
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    Every vehicle I’ve owned the headlights dimmed when the antilock brakes engaged.
  15. Jan 6, 2022 at 6:46 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    The more I think about it, the more it makes sense.
  16. Jan 6, 2022 at 7:15 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    My 18 sport does this, normal
  17. Dec 16, 2022 at 6:58 PM
    patbegley
    patbegley Well-Known Member
    The Kootenays
    '22 DCLB
    My 22 does this. Here to see what people are saying about it.
  18. Dec 16, 2022 at 7:11 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Normal, as mentioned @stevesnj , the ABs system draws a lot of power.
    I’ve had other vehicles do the same.
  19. Dec 16, 2022 at 8:19 PM
    patbegley
    The Kootenays
    '22 DCLB
    He also says "Still get your charging system checked, Alternator, battery,check all ground wires"
  20. Dec 16, 2022 at 8:37 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Well if you’re unsure,,, take it in.
    I’ll not Bother you any more
