Headlights Issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TAC0JR, Dec 21, 2023.
  1. Dec 21, 2023 at 3:21 PM
    TAC0JR
    TAC0JR [OP] Active Member
    2023 Tacoma TRD Off-Road
    Finished installing my headlights and noticed that the drivers side low & high beams don’t work properly like the passenger side. I’m using daveasa’s harness and made sure I connected everything correctly. Any idea what could be going on?
  2. Dec 21, 2023 at 3:42 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
  3. Dec 21, 2023 at 3:48 PM
    4runnerToTacoma
    4runnerToTacoma Well-Known Member
    22 SR5 V6 Taco, 03 SR5 V6 4runner
    I am not sure if I am only one but my 23 SR5 has same thing when it has hand/parking break engaged. When in park both lights come on but while engaged in hand/parking break, its like that too.
    Try disengaging parking break, but keep it in park obviously, and see if both lights set on.
  4. Dec 21, 2023 at 4:39 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Assuming that was you, I also replied to the email. Post or send a photo of your high beam connector on the driver side. Positive is solid white and negative is white with a black stripe. It is easy to mix them up because they look so similar. The curve of the female h9 connector matches the tabs of the male h9 connector as well, offering some visual feedback if you see the tab on the shallow side.
    doublethebass and Stevie17 like this.
  5. Dec 21, 2023 at 5:05 PM
    daveeasa
    David
    PNW
    Mods, if you see this, perhaps it makes sense to move the thread over to my vendor forum?
